Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 31st May 2006, 02:00 PM   #31
I_Forgot's Avatar
What are the blue cap values?
I_F
Old 31st May 2006, 02:52 PM   #32
Few is offline Few  United States
Printed on them is:
473
6KV
Since I measure 56 pF on each capacitor while it's still soldered to the board (but with its output lead disconnected), I'm assuming they're 47.3 pF caps.
Old 31st May 2006, 03:40 PM   #33
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
hmz ... 473 should mean 47nF caps , shouldn't it ?
Old 31st May 2006, 05:47 PM   #34
That's what I was going to say, but when I measured it to double check, I had a hard time rationalizing the results. I thought I could get away with measuring the capacitance as long as one of the two capacitor leads was disconnected from the circuit, but I guess I was wrong.
Old 1st June 2006, 02:49 AM   #35
I_Forgot's Avatar
The minimal info I can find on that particular inverter say it produces 1000Vrms. ccfl inverters can usually supply 3-5 mA out, though at a voltage a little lower than the open circuit (start-up) voltage value. Your rectifier circuit should charge the 300 pF cap to about -750VDC relative to ground. 750V bias won't make a sensitive ESL- maybe the output is low and you are not hearing it due to the low bias voltage.
When you connect a scope probe to the circuit if you connect directly across the 300 pF cap the probe's voltage divider is going to load the cap and discharge it. What is the scope probe's divider resistance? It doesn't take much to discharge a 300 pF cap. You may be charging and discharging the cap on each cycle, hence the AC that you see on the scope. What frequency is the waveform on the scope?
Another possibility is that your scope ground may be loading the 24V supply and killing the 24V going into the inverter. Check the input voltage while you are making the output measurement.
I_F
Old 1st June 2006, 03:36 AM   #36
rpapps is offline rpapps  Antarctica
Hi Few
I think you need to bypass that output cap and connect directly to pin 6 of the transformer. As it stands, there is no DC return path for the rectifier. Also, connect a 10 Meg resistor accross the 300Pf filter cap.
Cheers
Rob
Old 1st June 2006, 02:57 PM   #37
Thanks very much for the help guys, I really appreciate it. I'll give things a try and let you know what I discover. I need to track down some high voltage diodes first, though. The ones I was using left with a student I was helping.
Few
Safe use of unknown small signal transistors mashaffer Parts 8 29th July 2008 12:35 AM
in a CLC input supply: is it safe to use... jarthel Power Supplies 2 8th July 2007 11:39 PM
Fail Safe Power Supply Allen Newby Pass Labs 38 10th June 2007 07:14 PM
Safe to increase bias on factory Aleph 30's? hifimaker Pass Labs 5 18th January 2005 08:18 PM
Page generated in 0.08576 seconds (73.87% PHP - 26.13% MySQL) with 11 queries
