Electrostatic speakers, real ones and...Martin Logan - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 14th September 2002, 11:21 PM   #1
Electrons are yellow and more is better!
peranders's Avatar
Default Electrostatic speakers, real ones and...Martin Logan
Hi!
Can anyone explain the difference between a electrostatic speaker with high resistance diaphragm and with low like Martin Logan? Is it an advantage with "sticky" electrons.
Is this an old Quad?
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 110 paid.
Old 15th September 2002, 12:13 AM   #2
I thought M-L had a high-resistance diapragm - I used to own a CLS mark 1, where the diapragm was coated with carbon powder, resulting in a high resistance coating (approx 100 kohm, if my memory serves me well)
Old 15th September 2002, 03:30 AM   #3
MRehorst's Avatar
A high resistance diaphragm is used for ESLs to maintain "constant charge" operation. By having a very high resistance, the charge on the diaphragm is prevented from moving toward the center of the diaphragm when the diaphragm is deflected toward one stator or the other by the audio signal.
If the charge were allowed to move (low sheet resistance diaphragm), at extremes of excursion all the charge would move to the center of the diaphragm so only the central area of the diaphragm would be driven and the result would be distortion.
I believe Martin-Logan uses a vacuum deposition process to put an extremely thin metallic coating on the diaphragm. Whatever the method used, it is a very high resistance coating.
MR
Old 15th September 2002, 03:32 AM   #4
MRehorst's Avatar
No, it's not one of the Quad 57s. Not an ESL63 either. Could be one of the newer models (I haven't seen their guts), or someone else's speaker altogether.
Old 15th September 2002, 04:59 AM   #5
frugal-phile(tm)
planet10's Avatar
The newer models are close enuff to the 63 that you'd recognize a family resemblance, so these are another maker. I assume the damped part in the middle are tweeter panels?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th September 2002, 07:01 PM   #6
Angry Graphite
Over the years graphite has been the conductive coating of choice for many ESL makers. Graphite it a poor choice for everyone but the makers, guaranteeing a 100% failure rate. High voltage on the system will eventually drive the carbon (graphite) off as carbon dioxide.
Cyclotronguy
Old 17th September 2002, 09:44 PM   #7
MRehorst's Avatar
Eventually like when? I am still waiting on drivers I built 12 years ago to stop working.
No I haven't had them biased continuously for 12 years, but the force produced by the electric fields in the speakers is very weak compared to the force used to rub the graphite into the film.
The graphite coating will outlast foam speaker surrounds, belts and lubricants used in tape machines, esoteric CD players, and turntables. It will outlast most pots, many switches, most electrolytic capacitors, vacuum tubes, and a lot of other materials found in audio systems.
Graphite works just fine and lasts a long, long time.
MR
Old 17th September 2002, 09:47 PM   #8
MRehorst's Avatar
Uh, as to carbon dioxide...
I've never heard of graphite being converted to CO2 in a high voltage field. Do you have any sort of technical reference for that?
MR
Old 17th September 2002, 10:08 PM   #9
Default graphite coating
Yes,cyclotronguy is right - I had the stators on my Martin Logan CLS's replaced twice. Once was for delamination, and the other time was most likely due to the carbon issue. That is why ML went to the molecular deposition process (incidently, this is done for them by PPG corporation, using the same process used to deposit heating films onto aircraft winshields, for anti-icing protection).
It is also tricky to achieve a uniform resistance using carbon, since it is not a controllable process - it is easy to end up with more carbon on one portion of the diaphragm.
Old 17th September 2002, 10:32 PM   #10
Sorry, I no longer have access to the documentation; it belongs to my previous employeer.
Part of their normal operation required frequent fabrication of high purity carbon into electrostatic deflectors. The carbon and documentation came from a small branch of Union Oil that supplied the carbon in various forms.
Rate of re-dox was a time, charge, pressure, mole relationship; proportional to time and charge, inverse for pressure.
Martin Logan CLX distortion bolserst Planars & Exotics 6 12th August 2009 07:07 AM
amp for martin logan quest slr 5000 Pass Labs 2 8th June 2009 07:30 PM
martin logan's dsiroky Pass Labs 17 16th April 2007 11:13 AM
martin logan csl flodge Planars & Exotics 12 13th November 2005 03:59 PM
B&G NEO3 and NEO8 in Martin Logan speakers ?? cph2000 Multi-Way 3 7th March 2004 09:03 PM
Copyright ©1999-2017 diyAudio
