Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 3rd June 2005, 10:21 PM   #1
Default just to shake things up
How about building some ESL panels sideways with 100% solid flat insulated stator plates? They will require that one edge on either side of the diaphragm be left open so the air can escape when compressed by the diaphragm (front side/back side). You could run multiple sets side by side to boost output. You could even use this idea to make an electrostatic compression driver. Any thoughts??? Regards Moray James.
moray james
Old 3rd June 2005, 10:26 PM   #2
SY's Avatar
I'm not clear on your description. Any chance you could do a very quick sketch?
If there's a sucker born every minute, where do the rest of them come from?
Old 3rd June 2005, 10:49 PM   #3
Default I'am no artist
Sy: imagine that the stator plates are powder coated steel (solid flat). Now we have a diaphragm in the middle of 1/16 inch stator spacers(1/8 inch PP). If the unit is 4 inches deep by 36 inches long you will need to leave out two of the long stator spacers. One on the front (long) edge of the panel the other long one on the back (long) edge of the panel. The missing spacers will have to be on opposite sides of the diaphragm. So while the air is being squeezed out the front side of the panel on one side of the diaphragm it is also sucked in at the back side of the panel on the opposite side of the diaphragm. Does that make sence? Efficiency should be a high as it can get given solid stators with insulation. My only concern is air turbulance as the air compressed by the diaphragm is forced to exit/entre the unit via a gap only 1/16 of an inch by 36 inches long. Are ya with me? Regards Moray James.
moray james
Old 3rd June 2005, 11:07 PM   #4
SY's Avatar
If I follow you, you've got a situation where two out of phase wavefronts are spaced 4 inches apart. Or am I still not getting it?
Old 3rd June 2005, 11:41 PM   #5
Default Wish I could draw
Sy: this simply a regular ESL but with solid non acoustically transparent stators. So the sound can only come out if you put a hole somewhere. Turn the speaker sideways (so you are looking at it on edge) leave out just one stator spacer on each side of the panel on opposite sides of the diaphragm. So we are looking at the edge of the panel and one spacer on one side of the diahragm is missing and the opposite spacer on the opposits side at the back of the panel. So the diaphragm moves to the right and pushes air out the front edge of the panel while it sucks air in on the back of the panel on the opposite side of the diaphragm. Does that make any better sence? This is like a bad English comprehension test. Regards Moray James.
moray james
Old 4th June 2005, 12:02 AM   #6
SY's Avatar
That's what I thought. So you do have two out of phase wavefronts 4 inches apart. That's a problem. Another problem could potentially be turbulence in the cavity under hard drive.
Old 4th June 2005, 12:27 AM   #7
Default Any way you build it
Sy: I figure that any way you build a dipole you have out of phase waves from front side to back. So what's the difference? Am I missing something here? Could make a cool compression driver. I agree that turbulance could be a problem that was my first concern. Could build a hot damn line source tweeter though no trouble. Very wide dispersion. For horn loading very easy to set panel FS to match the horn. what do you think? Regards Moray James.
moray james
Old 4th June 2005, 12:54 AM   #8
Default Clairifacation
Sy: perhaps I should have said 4 inches deep. The idea is to have just one edge of the panel fireing forward with the opposite (back) edge fireing backward. Does that get us both on the same page? That way if you wanted more output you could laminate a bunch of these side by side by side to yield a combined output in a lateral stack of an inch or two wide. That should have a lot of air moveing. I suppose that you could control the depth to offset turbulance. Just a twist on the conventional format.
Built in a single panel configuration and used as a tweeter you could have a high output tweeter in a line source a 1/16 if an inch wide as long as you like. That should provide excellent dispersion. Enough output to keep up to a horn mid and or bass horn. Regards Moray James.
moray james
Old 4th June 2005, 01:03 AM   #9
Speakerholic
Cal Weldon's Avatar
Pssst... Moray
SY are his initials
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 4th June 2005, 01:23 AM   #10
SY's Avatar
Cal, I'm not a bug about capitalization. A regular ee cummings, that's me.
Moray, physically, the situation is different than with a flat planar dipole. It seems to me that you've got interference between the part of the diaphragm closest to the listener and the part farthest away. And that lag will always be 4" times speed of sound.
I have things sauuuuuce Swap Meet 0 13th October 2006 02:40 AM
Things important to be said..helped by Mr. John Mateus to express things. destroyer X Solid State 22 31st July 2006 07:21 PM
These things any good ? Madmike2 Multi-Way 4 13th July 2005 01:25 AM
A few things.... Ziller Everything Else 11 9th January 2002 04:44 PM
Copyright ©1999-2013 diyAudio
