Another DIY Ribbon thread - Page 78 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 19th May 2013, 06:37 PM   #771
Legis is offline Legis  Finland
Legis's Avatar
Originally Posted by tinitus View Post
try simulate this one
might have some advantage to use wider magnet, instead of squared.... like 0.5" x 1.5" (magnetised through thickness)
I don't get that model going too well? The Bl drops when the ribbon moves forward, and increases when it moves backwards, not good when designing for low XO and high-ish SPL... Side-to-side Bl-linearity also not as good as with basic model, the sides of the ribbon get considerably more driving force than the center. Correct me if I have simulated wrong.
Also that is not dipolar model, which I would like my ribbons to be. I might make them convertible between cardioid (forward firing) and dipolar with detachable steel-ish back chamber that would also redirect magnetic field. Or then I just damp the rear wave with some resistance/damping material, much simpler and might be more transparent acoustically/sound quality -wise.
Mentioned model with 1.5" x 0.5" (magnetization direction 90 and 270):
Basic model with 1" x 1":
Old 19th May 2013, 06:54 PM   #772
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
ahh...no, ok, I forgot....I dont think a ribbon should move that much
I have done tall man high ribbons in the past
sounded great, but I always found them too uncontrolled at more than low to moderate SPL
and I was missing some power in upper midbass and lower midrange
but the sim shows exactly what I have found too
that the magnet field is flat in a very precise spot, right in front of the magnets
anyway, thanks for doing the sim...much appreciated
Old 26th June 2013, 12:40 PM   #773
Rewind is offline Rewind  Sweden
Rewind's Avatar
Originally Posted by nikwal View Post
I'm hesitating about the gap between between the magnets.. as you can see in the pictures I'm trying to move them together. Anyway, they seem to work fine.
http://dsl.mine.nu/galleri/misc/band1.jpg
http://dsl.mine.nu/band.jpg
How did you attach the magnets to the U-bar? Did you dare to drill holes in them?
Old 26th June 2013, 02:46 PM   #774
They are actually just jammed into the U-bar with possibly some fabric or such.
The one who succeeded was the one who didn't know it was impossible.
Old 26th June 2013, 05:01 PM   #775
Rewind's Avatar
I have a Swedish 50cm long ribbon/1" wide ribbon transmission audio true ribbon driver, and I think he glued the nd magnets to aluminum front and backplates. It is open on both sides so they can
Sensitivity is low compared to TPL-150, maybe just 90dB. But sounds much clearer, but not as powerful sound below 3kHz, so I cut it off above that and use it as a supertweeter.
What do you think of this design?
File Type: jpg 1003814_10151404109706198_201329320_n.jpg (75.0 KB, 226 views)
Old 6th August 2014, 10:30 PM   #776
tony jazz's Avatar
Default transform 2 ohm to 4 ohm ribbon tw
can anyone help me? I need to transform from 2 ohm to 4 ohm ribbon in my tw I need some scheme of transformer thanks
File Type: jpg 1233490_501493879943528_260007405_n.jpg (278.8 KB, 119 views)
Old 7th August 2014, 05:29 AM   #777
Which is the desired frequency range?
Old 7th August 2014, 09:39 AM   #778
tony jazz's Avatar
the tw is an almost ribbon rispsta frequency 1700 Hz-40 kHz frequency of 2500 Hz recommended crossoer 2 ohm load I need trasforare the load to 4 ohms minimum help thanksan impedance transformer
Old 7th August 2014, 11:51 AM   #779
Why not use a resistor, that's all I ever use!
HENRY
Old 7th August 2014, 03:56 PM   #780
Work will be from 800 Hz ...But it's easier to add a resistor 2 ohm
Copyright 1999-2017 diyAudio
