Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 26th May 2010, 07:55 PM   #571
LineSource's Avatar
Alain Engineering (e-speakers.com), know as BEEngineering in Europe, uses a cylinder steel rear surround to complete the magnetic field and provide adequate rear-ribbon volume for extensive sound absorption material to dampen rear ribbon wave reflections.
The two NdFeB block magnets are up front next to the ribbon and form the two pole pieces. Since steel saturates at 1.5-1.7T, using steel next to the ribbon for the pole pieces will create a lower magnetic field than using NdFeB block magnet pole pieces. Large lower strength ceramic magnetics sometimes were put behind large tapered-tip steel pole pieces in order to concentrate the field into the gap at the saturated 1.5T level.
Alain also sells an 3-ribbon MTM design that stacks these cylinder structures. Cost: a few thousand dollars per ribbon.
Old 26th May 2010, 08:17 PM   #572
tinitus is offline tinitus  Europe
Ahh, nice pictures
I have seen those ribbons before, but didnt know it was like that
Its a neat design to use a round thick steel tube
But actually it looks more like a planar tweeter
Looking again it appears like theres two flat leads on diaphragm
One magnet on each side, an one magnet in the middle
Looks quite doable
Old 30th May 2010, 10:46 PM   #573
My new ribbon magnet system
Old 4th June 2010, 04:31 PM   #574
brunob is offline brunob  Germany
Looks nice.
What is the size of the magnets?
Is there a particular reason to leave a gap between the magnets?
Bruno
Old 4th June 2010, 04:34 PM   #575
Default 5 microns Aluminium foil
I would like to measure the same ribbon tweeter with 9 and 5 microns thick aluminum foil.
Does anyone know where to find 4 to 5 microns foil?
Thanks,
Bruno
Old 4th June 2010, 04:59 PM   #576
Paul W is offline Paul W  United States
Paul W's Avatar
I used 5 micron in my ribbons...believe it originally came from a film/foil cap winding facility. I also remember seeing a company in Germany producing it, but can not remember specifics...it has been too long.
Paul
Old 4th June 2010, 05:01 PM   #577
Originally Posted by brunob View Post
Looks nice.
Bruno
thanks
magnets are 1/4 x 1/2 x 1.5"
magnetized through thickness
I got them free from a friend, so the design is random and not that well planned
I consider it experimental proto
I have added a second copper layer (farraday), seperated with cardboard
Seems to give a small improvemnet in strength, and more flattened field shape
Old 4th June 2010, 05:12 PM   #578
Bruno
Good question
Well, if the magnets are forced closer together(ends), it appears to me like the general field gets weaker
I cant prove it tho
It also seems like there could be an optimal minimum/maximum gap size
Meaning that a very narrow field gap has no advantage in field strength
Old 5th June 2010, 08:06 AM   #579
Good question
I cant prove it tho
I think that is a very good idea! I made some simulations with FEMM. Woaw. I got an increase of the magnetic field from 0.20 to 0.73 tesla!!!!
More details later. I still have to find the optimal gap size.
Old 6th June 2010, 01:22 AM   #580
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Woah .. are you guys saying there is an advantage in having a gap between the magnets ?
Interesting Hmmm,,,,
Page generated in 0.11877 seconds (76.38% PHP - 23.62% MySQL) with 11 queries
