| Planars & Exotics ESL's, planars, and alternative technologies |
#31 |
Allo,
My original formula, V=BANw was rougly correct but I neglected to mention what "w" was - it's the so- called "angular freqeuncy", which is just 2*pi*f. My V is Vpk, divide by 1.414 to get the rms - if you apply these factors, you pretty much get: N = V / (4 * F * A * B) Actually, I think I get a factor of 4.44 there - I may have forgotten a scaling factor of 1.1 - that may have been if you use a square wave instead of a sinewave, 'fraid I can't remember. In any case, be conservative and run the transformer with plenty of magnetic (flux limit) headroom. I would concur that if a suitable mains toroid can be found, it may be a nice cheap option.They can have ridiculously good topend bandwidth Only thing to watch is the DCR of the secondary - don't want to throw away a load of efficiency. Anyway, best of luck - doesn't sound like you'll need it as you seem to be well on track. Cheers |
#32 |
Nothing new built or tested, but I was able to dig up some good tranformer references and answers to some of my previous questions.
First the references: Rod Elliot and his ESP site has a two part discussion on transformer design. I love that guy; he is one of the best DIY resources on the web. It's mostly about power supply transformers but there is enough about Audio and audio frequency losses to be very interesting: http://sound.westhost.com/xfmr.htm http://sound.westhost.com/xfmr2.htm Other good references: http://www.fair-rite.com/Broadband.pdf http://geek.scorpiorising.ca/windingtransformers.html Regarding my question about things that could affect transformer audio quality; It seems that the key thing to avoid distortion is to avoid running into saturation of the core (as CV said). Even though my calculation showed the transformer could handle 46 watts, I'll probably need to keep well below, maybe 30 watts, to avoid the saturation "knee" of the BH curve. Two things that can affect phase response and high frequency response are parasitic losses due to stray capcitance between windings and leakage inductance caused by imperfect coupling of the coil field to the core. To reduce capacitance it seems that I want to keep as much distance between the turns as possible. In other words, rather than having the turns touching each other in the toroid "hole", I should spread them out. It also seems to me that I definitely don't want to layer the secondary on top of the primary. The further apart the wires, the less capacitance between them (?). For inductance losses, I obviously want to wind the wire as tight to the core as possible for the best coupling (but not so tight as to breake or rub off the insulation!). I THINK I also want the primary inductance (and hence the number of turns) to be as small as possible while still meeting the rule of thumb of presenting an inductive impedance at Xover 5-10 times reflected load (i.e. 8 ohm * 5 or 10). You can't reduce the number of turns too much though, because it is directly proportional to the power handling capability. Lastly, I think I understand why my Version 1 transformer worked without blowing up my amp. The turns ratio was way too low so the reflected load was probably less than an ohm. The saving grace was that the 20uf low pass filter combined with the low impedance to produce a really high Xover frequency, maybe over 10k. There was so little power in that freqency range, especially listening to FM on a 30 year old receiver, that id didn't hurt the amp. If anything (or everything) I said is wrong, please let me know. I'm just trying to paw my way through all the information and learn something. I hope you folks don't mind me treating this thread as kind of a Blog of my investigation. It's the kind of thread I would have liked to find when I started looking at DIY ribbons. Denis |
#33 |
Hi dhenryp,
I can mail you some 0.7" wide 5.8 micron pure aluminum foil if you want to experiment. Just enable email on your user profile so I can get your home address. |
#34 | |
Done and Thanks! |
#35 |
Well I got my new toroids today. One of them came with a big chip in it;and that was the good news. The other one came in four pieces
I took the chipped torroid and made the Version 2 transformer. This wooks much better. It gives me an impedance of just about eight ohms. I've got jury rigged small gauge wiring and a couple of clip on connectors so I think I'm losing some efficiency on the ribbon side and effectively increasing its resistance with bad connections. The end result is that I got my eight ohms but only needed a turns ratio of ~ 8:1 (instead of my calculated 16:1). The primary inductance is 10mh and the leakage inductance (measured with an LRC meter and the secondary shorted) was .5mh. I don't know if this is good or not I got out my signal generator and and did some rough efficiency measurements. With 2.88v across the transformer primary I got ~85 - 87 db output (measured with my RS meter). I'm not sure how accurate this is but it seems in the ballpark, if a little low. Maybe it will improve when I get better ribbon connections and do a better job with the winding. The 5 micron aluminum foil that linesource is sending could also increase efficiency by several db. I can easily hit 100db from ~2k on up without obvious distortion on sine waves. I can probably go higher but have not gotten to it yet. Even the testing I've done so far has forced me to get out ear protection. Lucky I don't have a dog. Denis |
#36 |
Hey dhenryp how goes the transformer ?
You have been a great insperation to me with this project. You have made it look very doable. I hope you don't mind but I think I'm going to follow in your foot steps and try and build a couple ribbons for my self. I have a small machine shop and was thinking of getting a little fancier with the pole pieces. I was thinking of using iron pipe and cutting it to resemble the ALIAN BEEngineering ribbon tweeters. It would be nice to do a little magnetic modling tho. What software did you use, FEMM? where did you get it? The hardest part to this hole project seems to be the X-former. so I am very curious to see how yours turns out. |
#37 |
femm is great FREE 2-D magnetic modeling software that you can download for free here:
http://femm.foster-miller.net/cgi-bi...n/efileman.cgi I don't mid at all if you make your own ribbon. That's the reason I posted this thread; to share what I'm able to come up with. I played around withthe transformer last night and I'm quite happy with what I have now. I think a key to using the transformer is a steep enough high pass filter. I started out with a simple capacitor for a first order filter. I think the 6db slope is too shallow so that the low frequency that gets through at high volumes is enough to saturate the core, causing distortion. Last night I built a simple 2cnd order filter using components I had on hand: 14.4 uf cap and 1.2 mh coil. This gives me ~ 1k Xover frequency. With this I can play the ribbon louder than I can stand to listen too (within 10 ft) with no obvious distortion. When I build my final version for my line array I will probably go with a 4th order LR active Xover so it should work even better. The next things I'm going to work on are: 1. I'm going to increase the gap to .75". Femm says I should still get ~.42 Tesla in the gap so I don't expect efficiency to suffer. This will also allow me to easily experiment with the .7" foil linesource is sending (thanks!). 2. I've order all the steel and magnets to build two of the final line source ribbons. They are going to be ~48" tall with the net powered ribbon length being ~ 36" long. 3. I need to get my justmls measuring system set up. I just got a new computer so I will be using my old computer as a dedicated measuring system. This may take a little time, but I realize it's critical because up until now, most everything I've reported is subjective. Regards, Denis |
#38 |
The problem with wider gaps in ribbon drivers is not the field strength, it's the uniformity of the flux across the width of the ribbon. The edges of the ribbon will driver harder than the center. To an extent the corrugations will lend a bit of mechanical strength so that the middle is dragged along by the edges. There's a limit to how far you can take this, however, elseways everyone would be making 2" wide ribbons and we'd be able to get down into the 100's of Hertz before going over to another type of driver.
If you haven't already, try modelling the driver looking down its length. Yes, stronger magnets help. Good luck. Grey |
#39 |
I've been doing some reading on the web about how to reduce parasitic transformer losses. With the realtively small number of turns on a Ribbon matching transformer, it appears that capaciatnce between turns is not important - it's a different storry if you a build a vacuum tube output transformer with thousands of turns. Wire resistance losses are handled by using big wire.
The most significant loss for my application is leakage inductance. You can meaure it by shorting the secondary and measure the inductance across the primary. This leakage inductance can limit high frequency response and also can cause high frequency phase changes. This can be reduced a lot by using bifilar, trifilar, .... - generically called multifilar winding. For bifilar winding, you take two pieces of wire, twirl them together (not tightly) and then you wrap the pair around the toroid. Since you have two wires, you wrap the pair half the number of turns you've calculated (times two wires for each turn gives the correct number of turns). You have to connect the two primary wires in series in order to have the right number of turns. It's hard to describe in words so I've attached a diagram to show how it is wired for a three wire case (trifilar). This gives you a more efficient coil. It's not intuitive to me why it works but I think it was first invented by Tesla (yes, THAT Tesla) In the test I've done, I compared a standard wired toroid (one wire primary with a single wire seconday wrapped over it) to a toroid wired per the picture. They both had the equivalence of 30 primary turns and 5 secondary turns. I wired the primary in series trifilar. I think this has the most effect on leakage inductance. I wired the seconday with three wires in parallel. I think this mostly helps current carrying although it also has an affect on leakage. (I've not seen the terms "series" and "parallel" applied to these windings but it makes sense to me so I'm going to use it here). The bottom line; The bifilar wound transformer had leakage inductance about 1/3 of the standard windings. The standard transformer had leakage inductance ~ .5 mh and the bifilar was ~.16 mh. The primary inductance was slightly higher for the bifilar transformer (~5-10%) and the secondary inductance was unchanged. I also tried as high as hexfilar (6) primary windings with the primary and secondary twirled together (for maximum coupling). This made very little improvement (probably within my measurement accuracy). For my ribbon, I'm going to use 18 awg trifilar primary winding and probaly 20 awg quadfilar winding for the secondary. |
#40 |
If 1 inch of corrogated ribbon requires 1.3 inches of aluminum length in the flat, or there abouts, then,
--------------------------Alum Aly--------1100 ----------- 5052 ------------------------------------------2.9x10^-6-------4.9x10^-6 -----------------------------------------uohm cm3--------uohm cm3 ----------------------------------------------V-------------------V 6.3 micron (.00025") x .25wide = .096 ohms -------.162 ohms 10 micron (.0003937) x .25wide = .061 ohms --------.103 ohms 6.3 micron(.00025inch) x.25wide-----4ohms = 41.66 inches long -------------------------------------------8ohms = 83.33 inches long 10 micron(.000393inch) x .25wide----4ohms = 65.67 inches long -------------------------------------------8ohms = 131.14 inches long www.allfoils.com/products_aluminum_foil.html |
| Page generated in 0.15091 seconds (84.08% PHP - 15.92% MySQL) with 11 queries |
