Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 26th December 2004, 09:28 AM   #1
Send a message via AIM to dunderchief
Default Ribbon Tweet mounting Depth
Hi there,
I've come accross a situation that calls for an absolute minimum in mounting depth. I'd really like to use a Ribbon, but most of the ones I've been looking at have at least a 3" mounting depth. Namely the Raven R1 and AC G2si, both have the transformer mounted directly on the back of the driver.
My first question is: Is there a way to unmount the transformer from the casing and allow it to be mounted away from it, on the tweets that have this feature. Still very close to the casing, but just not right behind it. If I were to choose the Raven, would I be able simply to unscrew or detach the transformer easily?
Second Question: Are there any other options for ultra shallow depth ribbon tweets out there. I'm only looking for 5-6k on up.
Thanks in advance
-Steve
Old 26th December 2004, 12:30 PM   #2
CV is offline CV
Default no prob
...with the aurum cantus - you can just unbolt the transformer. It's basically an aluminium rod with the magnetics potted over it, the ends of the rod bolt to the tweeter plates and form the connections. Be sure to use very low impedance wiring...
cheers
Old 27th December 2004, 08:39 AM   #3
Default Isodynamics
Hi Dunderchief,
What about BG NEO's drivers? ( The same used in the new MartinLogan's AV speakers, if anyone have noticed........)
Also Eton ER4 can work ( his frequency response is very similar
to the NEO3 PDR in the same conditions)
Looking for small Ribbon Tweet Jlace Car Audio 3 11th April 2007 08:39 AM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 11:52 PM
Ribbon Tweet suggestions.... eastcoast Planars & Exotics 0 28th March 2005 08:33 AM
socket mounting depth tenderland Tubes / Valves 10 17th March 2005 02:55 PM
Tweet/mid flush mounting Puggie Multi-Way 3 17th January 2005 07:11 PM
Page generated in 0.08167 seconds (70.05% PHP - 29.95% MySQL) with 10 queries
