| Planars & Exotics ESL's, planars, and alternative technologies |
#61 | |
With sqrt(f) in the denominator, this tells you that with constant current fed to an ESL line source the SPL will fall -3dB/octave as frequency increases. Note also that sqrt(r) is in the denominator so response falls -3dB for each doubling of distance from the line source; a well known phenomenon. But, we usually think in terms of applied voltage since our amplifiers and step-up transformers are good approximations of voltages sources. Take a look at equation (5) from the paper where the Walker type equation is converted to Vsignal instead of Isignal: P=V(signal)*V(pol)*C*sqrt(f) / (d*h*sqrt(c*r)) Now sqrt(f) is in the numerator. So, with constant voltage fed to an ESL line the response will rise +3dB/octave with increasing frequency. This implicitly takes care of the dipole roll-off for low frequencies and directivity factor for high frequencies. This rise is exactly what the R-C transmission line is use to equalize out. For derivition and discussion of point source and line source Walker equations, see sections 3.3.2 and 3.3.11 of Baxandall's ESL chapter in the book "Loudspeaker and Headphone Handbook". Last edited by bolserst; 31st May 2010 at 06:16 AM. |
#62 | ||||
5kHz -> -0.2dB 10kHz -> -1.2dB 20kHz -> -5.5dB 30mm strips make that: 5kHz -> -2.8dB 10kHz -> -16.3dB 20kHz -> zero at 35 degrees (due to phase reversal) with lobes at + and - 60 degrees Quote:
Also for completeness max SPL is also determined by D/S spacing (but that is in turn determined by the LF breakpoint) and by Vpol (which is limited by the quality of your isolation). Quote:
![]() Quote:
Kenneth
Never send a human to do a machine's job. --Agent Smith |
#63 | ||
![]() According to the Baxandall ESL paper and my experiments, contrary to popular belief D/S spacing does not come in to play when defining max SPL. It only places a limit on how low in frequency you can put out that max SPL due to the physical constraints of diaphragm motion. The two parameters that define max SPL for an ESL are 1) area 2) breakdown voltage gradient for air. See section 3.3.9 of Baxandall chapter. For a given D/S there are particular values of Vbias and Vsignal based on the breakdown voltage gradient which will produce maxSPL. See section 3.2.9 of Baxandall chapter. With the area of an ESL held constant, if you double the D/S you double the required Vbias and Vsignal required to reach that same value of max SPL. However, with double the D/S the voltage gradient in the airgap is the same. Of course, that is theory....which I love! ![]() In practice, the higher Vsignal must be generated by a transformer with twice the step-up ratio which may place limits on the bandwidth over which you can reach that SPL. Also, as you mentioned, higher voltages may be limited by imperfect stator insulation, or sharp edges and/or dust in the air gap. Quote:
#64 | |
Hi there,
My mistake.This thread got me thinking. For some reason we European DIYers build mostly wire stators. Now it would be very easy to bring out every single wire as a separate signal once the wires have been glued down. If I ever build another panel I will definitely do that. This'll result in very narrow sections 3...5mm and should give superior dispersion. When I built my current panels as a young and reckless man (that was 6 years ago) I lacked the foresight to make the stators separable, so I'm kinda stuck now to my 25mm center section surrounded by 3 big sections of about 70mm. As you would expect, it's pretty beamy but in the sweet spot it's, well, sweet! Kenneth
#65 |
Great info guys.
Can't wait to see your spread sheet program,Steve. After I get caught up in my things that have to get done now list,I will be able to start a new set of panels, as I have just bought all of the materials to do so. With my method of construction ,this could very easly be applied. My little panels are only 85mm wide and do get quite loud down to 300hz in a nearfield configuration. I had thought about taking a few swipes with a dremel tool to segment the stators ,but I'm sure this would prove difficult to reseal the edges to stop the arcing. A new panel build would take as much or less time to make, while not having more than needed sharp edges to contend with. I would like try this method as I don't particularly care for the beaming effect as well, either. So it will be interesting to compare two sets of panels of identical size and exprience the effect. From everthing I have read that segmented stators are the way to go if done properly. jer |
#66 | |
Hi again,
In The Netherlands there's a guy who took the other approach: no segmentation but using an amplifier which acts much more like a current source. (The fact that it was a direct drive amp helped in the realization of such a behavior). Check it out here: Elektrostatic Loudspeakers - Frank Verwaal NOT the approach I would take, but there's a wealth of information on that site. Oh and here's an online simulator which can be useful: Electrostatic Loudspeaker (ESL) Simulator Kenneth
#67 |
Here is the XL spreadsheet.
I appologize for the mixing of units, but at least I labeled them. I tried to list all the assumptions and equations on the "Notes" & "Directions" tab, but may have missed some. Let me know if you notice something missing or the directions don't make sense. A few observations: 1) Native response of floor to ceiling ESL is sloped +3dB with increasing frequency 2) maxSPL increases linearly with Panel width. 2) maxSPL does not change with height of line source. (for more details see the "Notes" tab) 3) maxSPL decreases -3dB for each doubling of the listening distance. 4) maxSPL is NOT dependent on diaphragm to stator spacing, although the required Vsig & Vpol required to achieve it increase linearly with D/S. Note that this does not mean that you can use whatever spacing you want to go as low as you want. The spacing still must be defined to allow the required diaphragm motion for maxSPL at the LF breakpoint. 5) If you want to go low by setting the LF breakpoint low, efficiency suffers unless you increase panel width to compensate. If you want it loud, make it a hybrid. If you want it loud and low and don't want a hybrid, make it wide. Enjoy. |
#68 | |
I missed getting that put on the "Notes" tab. From the book "Acoustics" by Beranek, equation (1.18): SPL(dB) = 20*LOG(P/Pref) where: P = sound pressure (N/m^2) Pref = reference sound pressure = 0.00002 (N/m^2) From what I understand, SPL is an RMS value and the sound pressure values calculated from the Walker equations are peak pressures. So, I multiplied the pressures values coming from the Walker equation by 0.7071 before calculating SPL. Last edited by bolserst; 3rd June 2010 at 02:41 PM. |
#69 | |
http://quadesl.com/speaker/diyesl/polar_fine.gif It's not practical for a casual listening speaker, but for a single person ride, it's not bad. Sheldon |
#70 |
In Frank Verwaal papers there is a table (Part #2 p.80) with the RC filters to be used for linear frequency response. Next figures show the implementation of the idea.
So, am I right, assuming: 1) for different stip widths the table and individual resistors per stip (Fig.#1) is applicable. 2) if the ladder structure is employed (Fig.#2) then all the resistors are equal, strip width are all the same and bolsert's spreadheet is applicable, as well as the AES article we discussed. Alex |
| Constant Directivity Horn EQ | Horizons | Multi-Way | 4 | 19th December 2008 11:41 AM |
| Constant directivity EQ | Saurav | Multi-Way | 11 | 19th May 2008 02:41 AM |
| Constant directivity horn - or waveguide? | hasselbaink | Multi-Way | 6 | 1st April 2008 01:24 PM |
| A question on directivity | swak | Multi-Way | 18 | 31st July 2005 03:03 PM |
| Open baffles and directivity | Yuihb | Multi-Way | 18 | 27th February 2004 08:22 PM |
