Esl 63 what type of coil for the delay line? - Page 2 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 22nd November 2004, 10:23 AM   #11
hilbren is offline hilbren  Netherlands
your calculation sounds good, its almost the same as the total delay line of a quad esl63.
but i dont think its done with the extreem long wire. i think its done with LC circuit and not on the fact that eletricity needs time to travel trough an extreem long wire...
ive got some theroies from Peter Baxandall i will post some screenshots from his book to explane the theorie...
Old 22nd November 2004, 04:18 PM   #12
For a thorough analysis of the ESL63, read the chapter on electrostatic louspeakers by Peter Baxandall in the book Loudspeaker and headphone Handbook, edited by John Borwick. (ISBN 0 240 51371 1)
Peter Baxandall was a good friend of Peter Walker and had a full mind dump from him for writing the chapter, along with contibuting much understanding from his own experiments. There is no better treatise available on the subject.
The theoretical and practical work that went into devising the ESL63 was extensive, as you will see from the book. It was an astonishing undertaking to develop and shows just how much more PJW contributed to the science of electrostatics than anyone else.
I admire your wish to try to experiment with your own solution, bet be prepared for a lot of work!!!
Good luck
Andrew
Old 22nd November 2004, 10:25 PM   #13
expert in tautology
bear's Avatar
Yeah... Borwick... Loudspeaker & Headphone Handbook.
That was the book I was trying to recall...
There was a schematic there, but I doubt that it had values for the inductors. The hair thin wire is probably because of the number of turns required to get the requisite L... with the signal being essentially low current and high voltage, I guess he was able to get away with fairly thin wire keeping the coil size modest.
I've had then open on the bottom... to change out the cheap binding posts for some better ones... didn't recall anything remarkable looking about the coils at the time.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 24th November 2004, 02:54 PM   #14
I did some caculations that explane the lenght of the wire, i came out with 4,5 H thats a BIG coil :P
Old 24th November 2004, 05:13 PM   #15
rcavictim's Avatar
You cannot use a wound coil of a long piece of ordinary wire as a delay line, it will be an inductor in that configuration. The problem is the mutual magnetic coupling between all the turns. A large inductor will only cause all the high frequencies to be lost.
You can however make a delay line with a long piece of coaxial cable. It is acceptable to roll this cable in a coil to make it more compact. You will still have a HF slope rolloff issue which is normal for coaxial cable and is a linear relationship to the length of the run. This can be compensated for in most cases with a suitable pre-emphasis network to artificially boost the highs prior to insertion into the coaxial run. DC resistance of the coaxial cable center conductor will not be trivial and it's effect on the system will depend solely on the current flow which is a function of the voltage supplied by the amplifier and the impedance of the loudspeaker. Simple ohms law calculation. If the cable run is the same impedance as the speaker then half of the power will disappear as heat in the coaxial cable. An electrostatic driver is an extremely high Z so losses in the coaxial cable will be greatly reduced compared to trying to run an 8 ohm dynamic driver.
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Old 24th November 2004, 06:10 PM   #16
yes but the speed of elektricity in copper is 230 000 000 m/sec
so if i want a delayline with 100us delay (total), i need 2,3km of coax
but it is an option, I only need a very compact coax cable
another idea based on the coax...:
what if i wind a coil with for example 1000 winding to the left and the another 1000 to the right. the the coil isnt inductive.... but the delay still exists...?? would that work?
Old 25th November 2004, 04:41 PM   #17
expert in tautology
bear's Avatar
You can however make a delay line with a long piece of coaxial cable. It is acceptable to roll this cable in a coil to make it more compact <snip>
Obviously, this is incorrect.
If it were so, there would be no Quad 63.
Peter Walker explained how this works with ESLs back in the 1950s... and yes it uses inductors.
There is a configuration known as an All Pass filter... it provides
delay without HF loss.
_-_-bear
_-_-bear
Old 25th November 2004, 05:05 PM   #18
rcavictim's Avatar
_-_-bear
I heard the delay line in the '63 uses some 12-14 kM or miles of wire.
You can use inductors, but not one single large one to make a delay line. It has to be a long string of L, then a C to ground, L, C to gnd, L, C to gnd, etc, etc, etc. That is the description of a long piece of coaxial cable! HF loss compensation will be required. Sometimes known as 'tilt'. The delay seen is some fraction of the speed of light based on the velocity of propagation in the cable (VP). Usually this is around 66% C in solid dielectric polyethylene coaxial cables.
What exactly was incorrect?
Old 28th November 2004, 04:19 PM   #19
expert in tautology
bear's Avatar
Yes, but this is merely a coincidence - the requirement being to get sufficient L in order to have the requisite time constant given the value of C (the cells) being low.
Then length of the wire is a "factoid" that is used for marketing hype and discussion - nothing per se to do with the electrical delay.
It seems that you have not seen the schematic for the 63?
That the length of the wire was what delayed the signal.
This delay line in the 63 is not the case of a coaxial cable made delay line.
_-_-bear
_-_-bear
Old 28th November 2004, 05:28 PM   #20
rcavictim's Avatar
Bear,
No I haven't seen the 63 schematic, but I know a little about delay lines, and it is the velocity of propogation that sets the delay. I will reiterate that a single L and C will not do the trick, all you get from that is a low pass filter.
You don't have to have an actual length of coaxial cable though. You can simulate it elecrically in other physical forms. One example. Make what superficially looks like a large bobbin would air core choke. This would be a layered air coil but each layer would have a copper foil shield above and below the turns of wire on that layer. The turns would be spaced on each layer to reduce capacitive crosstalk to adjacent turns.
A copper wire with enamel insulation sandwiched between two copper foil ground planes is electrically an actual 'transmission line'. A form of this is also manufactured commercially called tri-plate line or printed on circuit boards this way for microwave use. What you would see in schematic presentation of such a device would be a series L followed by a bypass C to ground (the foil shield), then another series L followed by a bypass C, etc, etc, etc.
Quad or anyone else reputable isn't going to advertise 14 kM of wire in the crossover delay network unless it is true. Your comment about coincidence and factoid nonsense for better play on advertising is IMO your own mistaken misbelief.
Acoustat Spectra Delay Line - Any Experts? Magnetar Planars & Exotics 6 7th February 2006 07:25 PM
Low-Cost Audio Delay Line Uses 1-Bit ADC bobo1on1 Digital Source 8 19th April 2005 04:53 AM
Line level signal delay circuit wigginjs Solid State 3 26th September 2004 02:51 PM
Line level signal delay circuit wigginjs Parts 2 24th September 2004 11:36 AM
Group delay of a transmission line? 454Casull Multi-Way 4 8th July 2004 02:34 AM
Copyright 1999-2017 diyAudio
