| Planars & Exotics ESL's, planars, and alternative technologies |
#41 |
Would the "booster" magnets perhaps be to force the main magnet's flux into the desired gap? Since they would have to be the same polarity as the main magnet, this would be exactly the same as having a larger magnet with a shaped pole-piece...
By the way, I'm campaigning to outlaw the following words in marketing copy or newspapers: Booster Revealed Quantum Perfect Invention There may be others...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#42 | |
Account Disabled
BTW, on http://www.transmissionaudio.com/pages/738785/index.htm where they compare other speaker technologies, under ionic/plasma they list the low quality RF-driven corona discharges, but do not mention the Plasmatronic's superior technology. Somehow I doubt they'll bother to correct the omission if I prompted them. |
#43 | |
Price, though. |
#44 |
Can't recall exactly now, but I think I remember that even Berrylium (not just the oxide) is scary toxic...
The ultra HF tweeter from TAD uses a Berrrylium diaphragm, afaik. Don't have the requisite table in front of me to check the conductivity... I'll have to take ur word on it. Certainly possible but other than TAD no one has tried it. _-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#45 |
Doesn't focal use beryllium in their tweeters?
From what I've heard it is HIGHLY toxic when being manufactured, but completely safe by the time it is in the driver. That just adds to the price. (Those TAD drivers aren't cheap) |
#46 | |
have been doing so since the beginning of the 1980's so that's nothing new. The bass ribbons go down to 30hz for both my small ones and big apogee's. The homogenity, clarity and low level detail is still unmatched. Undtill recently the problems has always been finding a good amp to match them. But class D amps seem to work perfectly. To see how the apogee bass is mounted look at this DIY rebuilt of a Scintilla; Scintilla rebuilt project For people interested in the latest evolution from the original apogee design look at this: Scroll down to blast-off I hope Guido and Graz are ok with me posting this link. |
#47 |
Hi Eric and Apogee fans,
Purchased 80” high Full Range Apogees with broken midrange ribbons. They came with the standard passive bi-amp crossover that went between the preamp and two power amps. It had 6db slopes at 320Hz to the bass panel amp and to Mid+Tweeter ribbon amp which then drove a standard 6db passive crossover at 10KHz using an inductor to the midrange ribbon step-up transformer, and a capacitor+padding resistor to the tweeter ribbon. The bass panel is ~2 ohms, 2” wide midrange ribbon ~ 0.1 ohm, and 0.5” wide tweeter ribbon ~ 1 ohm. A transformer brought the midrange ribbon up to 4 ohms, and a series padding resistor balanced the power to the tweeter ribbon. Currently bi-amping using active 48db LR8 crossover at 80Hz from the bass panel amp and a DIY direct-drive ribbon amp, and a 12db passive crossover at 5Khz between the mid and tweet ribbons. The original 15 micron thick ribbons were replaced with 5.4 micron ribbons, which almost tripled efficiency and resistance which makes direct drive easier. The midrange ribbon now covers the entire vocal range, which is the key to a great speaker, and there is no set-up transformer to create phase shifts. The 48db slope at 80Hz sends less bass power to the ribbons than the original 6db at 320Hz. The 25W Class-A ribbon amp uses +/- 12V driver supply with +/- 8V output supply to drive the low impedance, also keeps the circuits simple and heat low. |
#48 |
In its as-finished state (assuming the dust is removed), beryllium will pose no hazards as long as you don't touch it or scratch it or something along those lines.
#49 |
I'm not really convinced there's anything worth looking at here. Maybe once I see a review, or hear them in a hifi shop.
I agree with previous posts that he brushes off other technology. On one part of the page it says something to the effect of: "It took a year to find a vendor that met our quality standards. This makes me believe it's a "catalogue manufacturer." ie: He looks through catalogues to find parts, and throws it together. The only way I could think of to increase the impedance of a ribbon driver is to have sandwhiched layers of aluminum and mylar. Then the individual layers could be wired in series. |
#50 |
On further reading of his site in several places he makes the claim that there's less chance of hearing loss at high SPL's. SPL is SPL, plain and simple.
He reminds me of one of those guys that claim to have developed a perpetual motion machine. |
| A new speaker technology | GRollins | Planars & Exotics | 28 | 10th February 2009 10:04 AM |
| New Speaker Technology - The Future | hifimaker | Multi-Way | 4 | 9th February 2009 02:39 AM |
| Technology Student Building Speaker | morfius | Multi-Way | 13 | 8th September 2007 08:44 PM |
| the perfect speaker | scottie2hottie | Multi-Way | 9 | 4th November 2002 02:10 AM |
| Page generated in 0.13119 seconds (83.34% PHP - 16.66% MySQL) with 11 queries |
