Replacing neon lamp for charging indicator in Quad ESL63 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 9th May 2017, 04:29 AM   #1
Default Replacing neon lamp for charging indicator in Quad ESL63
I need to replace a neon lamp in the charging indicator circuit for Quad ESL 63. Anyone has its spec and where can I buy it? Thanks in advance for your help
Old 10th May 2017, 04:14 AM   #2
So quiet here... anyone?
Old 10th May 2017, 08:30 AM   #3
Thinking... searching....
Old 10th May 2017, 08:41 AM   #4
Mooly's Avatar
General purpose neons seem to be widely available from component suppliers:
Neon Bulbs | CPC UK
Most neons operate at around 90 volts so its a case of finding one of the correct outline.
Old 10th May 2017, 09:06 AM   #5
Thanks, guys. I'll check it out.
Old 10th May 2017, 10:46 AM   #6
Drop Kent McCallum or Sheldon Stokes a line - they know.
http://www.quadesl.com for Sheldon
http://estatsolution.com for Kent
Sent from my Nexus 6 using Tapatalk
Old 10th May 2017, 01:02 PM   #7
I used an off the shelf neon bulb from the electronic shop. I dont expect it o be a critical thing. Just be sure it is a bare neon bulb without any internal resistor
drs M.J. Dijkstra
Old 11th May 2017, 04:51 AM   #8
Thanks, guys
Old 11th May 2017, 07:15 AM   #9
Calvin is offline Calvin  Germany
Calvin's Avatar
the voltage printing on the cap that is in parallel to the neon bulb might give a hint on the bulbīs specs.
I assume it is >>100V as many small neon bulbs in screwdriver phase-testers are specced for a flashover voltage of ~90Vac (flash-off ~60V).
The voltage rating of the Cap must be higher than the flashover voltage of the bulb (keep dc and ac values in mind!).
Look for example the Datasheet of the "Glimmlampe" at Reichelt.de
If You order a lamp with series resistor just cut the resistor off (models "L 2108" - clear, "L 2111" - red, "L 2113" - green)
jauu
Calvin
Old 11th May 2017, 10:37 PM   #10
Found several at Digikey
Neon lamp charger vasko Power Supplies 32 14th December 2012 06:20 PM
Neon Lamp Question avengerman14s Tubes / Valves 6 1st November 2011 08:03 PM
Wiring SPST Switch with Neon Lamp PhrazeMaster Construction Tips 5 9th January 2011 08:28 PM
Where can I get a neon lamp for Garrard 401? happycat Analogue Source 12 10th March 2006 06:56 PM
Quad Esl63 rebuild SumTingsBurning Planars & Exotics 6 19th May 2004 03:26 PM
Copyright Đ1999-2017 diyAudio
