Dual, front and rear firing Acoustats - Page 3 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 24th March 2017, 01:29 AM   #21
tyu is offline tyu  United States
ML CLX bass panels is made with dual mylar layers .....Cool
thanks for the info
Old 24th March 2017, 08:32 PM   #22
Originally Posted by Steve M View Post
Disco Pete: Rob MacKinlay of ER Audio here in Australia was developing a dual layer stat panel along the principles of what you have jerry rigged with your Model 3 set up. He told me at the time it had great potential to strengthen the sound field of stats and give a positive result in the manner you are describing with yours. Not sure Rob proceeded with the concept though? It was a few years ago we discussed all of this ...
Steve.
I think what may be a factor is that the rear firing panels are powered separately.
Old 27th March 2017, 10:25 PM   #23
Well, after extensive listening, I've come to the conclusion that in this particular experiment, the Monitor 3 by themselves is best. Not as dynamic but flatter, more linear sounding.
WrineX has brought me to my senses.
Old 28th March 2017, 11:35 AM   #24
It was a valiant effort. The Magneplanar mod community has made minor improvements by reinforcement of the frame holding the panels.
Sent from my Nexus 6 using Tapatalk
Old 28th March 2017, 04:30 PM   #25
Hey, no complaints here.
Old 31st March 2017, 04:21 PM   #26
bolserst's Avatar
Originally Posted by gnnett View Post
The Celestion 6000 sub woofer for the SL600 was a bipolar, back to back dipole arrangement, or was this an open isobaric dipole arrangement as Winrex describes?
The Celestion 6000 was a compound dipole, both dipole woofers firing acoustically in the same direction.
More details on the concept here (including a Celestion White Paper):
Legacy Whisper bass?
Originally Posted by Discopete View Post
…WrineX has brought me to my senses.
Yup, Wrinex described the situation correctly.
In case anybody is interested, Wrinex had started a thread where he was investigating stacking of multiple diaphragms in close proximity to each other. There was a spreadsheet posted that could be used to investigate the result of different number of diaphragms and spacings between the diaphragms.
sandwich esl ?Yummie
Using that spreadsheet and estimating the distance between your two panels at around 300mm give the results shown in the attached pics. With the panels acoustically in phase you would get a 6dB bump in LF output, but midrange and higher is compromised with phase issues. Putting them out of phase results in substantial cancellation of output, which agrees with your comment back back in Post#3 “I tried them out of phase and that just sucks the life right out of the sound”
Old 31st March 2017, 07:05 PM   #27
Thanks for that input. I think for my next experiment I may try a full isobaric trial. There's room behind the Monitor 3s to mount directly against them. I'm thinking to use foam gaskets firstly unbroken and then with gaps.
Hey, I have 9 panels!
Old 1st April 2017, 10:51 PM   #28
Make that 12
Dual-gang linear pot as splitter and front/rear balance control? booksix Car Audio 5 12th July 2012 02:13 AM
Front & rear end DUAL Back Loaded Horn + Bass Reflex Hybrid Enclosure nickthevoice Multi-Way 13 19th May 2009 03:09 PM
how to avoid transmission line resonance with front and rear firing dipole tweeters? thadman Multi-Way 7 14th June 2007 07:09 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
searching software to switch front speakers to rear and rear to front!-dolby surround MCM Everything Else 6 6th February 2004 09:29 PM
Copyright ©1999-2017 diyAudio
