i activated my segmented ESLs a time ago, have 2 different good working transformers for bass and wide-midrange but i still watch out for really good treble response. The Stax SRD 6/SB headphone supply contains 2 small transformers
but i don't know any specification. Since from time to time they appear at low cost on ebay i wonder if i should give it a try. The treble-segment has ~80pf, so that is slightly less than the Stax headphones have(110..130pf). I highpass above 15kHz with 6dB, sonical crossover is about 10kHz.
Does anyone know about the uppper frequency response of this transformers and should i try it out?
cheers
Carsten
cheers
Carsten
you are probably the only one which is trying this, good luckDoes anyone know about the uppper frequency response of this transformers and should i try it out?
i dont know what the ratio is but i dont see why it should not work ? its an audio trannie... depending on ratio how loud it is , and for a tweeter 10khz up you can use very low DC spacing as well as size.
ofcourse i dont know how well they perform up high. but if a 50hz power transformer can i can imagine this one can pout out some 10khz
i have tried several torrodial power transformers, they worked find in midrange but not for upper frequency. Today is frickling day and in the evening i will know if it worksbut if a 50hz power transformer can
i hope my expectations are not too far away from reality
...the problem is in the capacitive reactance. I also had to recalculate working points for optimal behavior, thd.
Maybe for stat speakers, this iron is not enough.(voltage wise)
https://www.ringkerntrafo.nl/shop/high-end-audio/esl-step-up-trafo.html
see that 5x primary windings ? think parasitic inductancei have tried several torrodial power transformers, they worked find in midrange but not for upper frequency.
ok, finished and rebuild the speakers.
The transformes work nice in their range. Ratio is 1:60
i don't need the weired xover at 16 khz anymore which was a cheat to get any sparkling.
At the moment xover is at 10khz/6dB and level is regulated down.
i did not do any measurement or comparism yet but i'm happy with that.
- Planars & Exotics
- Stax SRD 6/SB transformers for segmented speaker-panel above 10 kHz ? ?
