QUAD ESL 57 A little work on the loudspeaker - Page 10 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 20th March 2017, 07:28 PM   #91
Nemeske is offline Nemeske  Hungary
Nemeske's Avatar
Little step happened this weekend. The original FH screws were corroded way too much that I opted to replace them. I sourced again some FH titanium screws (from ACER racing) to do the job. Two problem arised with it: these tags had different thread size than M3, (maybe UNC #4) so I had to transfer these to M3. It wasn't too difficult. My other problem was I could only source FH screw with 6mm the shortest, so I also had to enlenght the holes in these tags. I am sure, these won't start to corrode for the next 200 years...
Old 21st March 2017, 05:28 PM   #92
Nemeske's Avatar
Completed one bass panel. It was a fun except the stage when one have to pull the wires through the tagboard without puncture the dustcover and broke off the solder post. That was a real pain in the *** work... The funny side was that Quad mustn't had any quality control when they were manufacturing these loudspeakers... The dustcover frames were shorter with a good 3-4 mm than the panels' itself... Anyway, it sings with great rattles at some frequencies, but I am going to remedy that when the panels will be at the frame.
Old 7th April 2017, 04:18 PM   #93
Nemeske's Avatar
The ordered M3*8mm titanium-aluminium screws and nuts has arrived, so I completed one more treble panel.
This time, I used some mahagony mordant to color the frames. I had to be careful with the amount of water to avoid deformation of the wood.
Old 7th April 2017, 04:20 PM   #94
Nemeske's Avatar
Also, I painted one side at a time and pinched it together to be sure not to bend the frames
Old 9th April 2017, 03:02 PM   #95
Nemeske's Avatar
Powder-coated the frame this weekend. There is one more bass panel to go (I ran out of the high tensile hook-up wire). The final assembly is getting real close...
Old 9th April 2017, 06:09 PM   #96
tyu is offline tyu  United States
WoW ....lot of great work here on the 57s...thanks for your time an info an the pic...
Vary Vary nice...
Old 10th April 2017, 03:54 PM   #97
Nemeske's Avatar
Thank you for your attention, tyu! Yes, it has required a lot of work so far... I am trying to refurbish the speaker as analitical as possible but making the smallest changes to the design itself at the same time
Old 19th April 2017, 08:15 AM   #98
Do you intend to keep the acoustical damping felt on the rear side? I am interested in your experience with/without it.
Old 19th April 2017, 08:58 AM   #99
Personally I think the felt spoils the potential of the speaker. I have had mine since the mid 1980s,and when I first bought them I was disappointed. They had a transparent yet closed in sound, they didn't breath... and the high frequencies were affected by a slighty phasey effect. This was in a room with them well away from the walls which were well damped with curtains behind. I was ready to give them up within a few days and then I remembered reading about removing the felt. I first did the bass panels, and that helped, but it wasn't until I removed all of the felt behind the treble panels that the magic appeared. I couldn't stop listening that night...
Sent from my x600 using Tapatalk
Old 19th April 2017, 11:34 AM   #100
Nemeske's Avatar
Well László, I haven't had the chance to experiment as I had bought the speakers without any felt on the back, not even on the trebles, they were removed and disposed by the previous owner (or owners). However, I always used the speakers at home with some damping the following method: we made a ,,special" thick cover for the speakers out of drape and some damping fabric for covering the speakers when they are not in use. I always put these at the back when they were in use. I liked it because it absorbed the sound somewhat that reflected from the back and made a better stereo image. But I must mention that the speakers sounded way better when I auditioned them at the seller's place. He lived in a house and the speakers were farther from the back wall that I cannot imitate at our flat.
Stacked Quad ESL 57 Tubenstein Planars & Exotics 46 23rd March 2014 10:07 AM
Quad ESL 57 panels? Simon T Planars & Exotics 5 8th February 2012 06:09 AM
Quad ESL 57 connection discurio Planars & Exotics 3 20th April 2011 02:25 AM
QuAD ESL 57 Question dude007 Planars & Exotics 30 5th March 2010 07:45 PM
Quad ESL-57 (pair) TimA Swap Meet 2 14th November 2005 11:34 AM
Copyright ©1999-2017 diyAudio
