#92
SF-T-60 tweeter. Frame size 50 mm. Max power 100 W (with crossover). Sensitivity 93dB. Resonant frequency 1 kHz. Frequency range 2500-30000 kHz. Diaphragm: Mylar. Nominal impedance 4 Ohms. DC resistance 3.5 Ohm Wiring:silver. NdFeB magnet. Pleat height 3.5 mm. Weight 0.37 kg
Sorry if the terms used are not acoustically correct.
- Planars & Exotics
- Tweeters handmade
