Anodized aluminum electrostat stators - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 6th July 2015, 03:38 PM   #1
Default Anodized aluminum electrostat stators
Does anyone have experience with anodized aluminum stators for electrostats? How does this compare in cost and performance to painted stators?
Old 6th July 2015, 07:30 PM   #2
Calvin is offline Calvin  Germany
Calvin's Avatar
You donīt achieve the insulation levels required for a safe-to-touch stator.
If You can insure that the statorīs be never touched the anodizing could provide just enough insulation to keep a sysmmetrical ESL from flashover, as in theory the voltage difference between stator and diaphragm becomes 0V when they touch.
The electrical parameters of the anodized layer are useable.
Iīd assume though that the rough surface will likely accumulate dust and humidity and as such itīd be prone to develop leakage over time rather faster than other coatings.
jauu
Calvin
Old 7th July 2015, 04:16 PM   #3
alexberg's Avatar
Due to porosity of oxide at particular treatment it can be impregnated and achieve rather high quality insulation level. What would the price though - it's very time consuming process. I've heard claims of 3..5 kV anodizing techniques to replace discrete corundum insulating washers.
Old 1st February 2016, 09:01 PM   #4
Just to add my experience to this thread for anyone interested. I built panels from anodised aluminium staters that worked well on a bias of 3kV. The stator panels were 300mm by 800mm by 2mm thick and were anodised by a supplier here in West London. I ask for soft anodising which builds a thick layer of anodised Alu, which is just Aluminium Oxide, a form of ceramic. I never experienced any form of insulation breakdown and would consider using them again. As for benefits I think the only advantage is aesthetic.
Old 2nd February 2016, 04:33 AM   #5
alexberg's Avatar
It has to be porous. Otherwise you can not make thick layer since Al2O3 is dielectric and current does not flow through one. Usual media in what aluminum oxidation takes place is an etchant like liquid glass. It does not mean the end result can not be a dielectric.
Grounding a chassis with anodized aluminum coating bkdc Construction Tips 14 11th April 2015 10:08 AM
Anodizing anodized aluminum Thomas Giz Construction Tips 8 11th June 2011 07:37 AM
Remove printing from anodized aluminum cent88 Construction Tips 12 1st February 2011 02:51 AM
Anodized Aluminum Heat Sinks clm811 Group Buys 39 3rd February 2009 06:45 PM
Anodized Aluminum and Glue/Epoxy Bryan Tubes / Valves 22 19th May 2004 12:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright Đ1999-2016 diyAudio
