35" Ribbon build - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 2nd May 2015, 06:06 AM   #1
Default 35" Ribbon build
Hi Guys, I thought I would share some images of a build im doing for a client in South Africa. The ribbon is a 5 segment it measures 6 ohms resistance and is 18mm wide and 35" long. The client wanted a narrow baffle similar to the B & G Radia 520i. The baffle is 1.1m x 220mm wide. Iv used nylon bracing bars to try and keep the flux centred between the ribbon. My magnets are N37 3/4" x 2" x 1/4". My pole pieces are 3/4" x 3/4" solid bar (No idea how this measures on Femm) IMG-20150501-WA0014.jpg
Old 2nd May 2015, 06:10 AM   #2
Old 2nd May 2015, 12:47 PM   #3
tyu is offline tyu  United States
Vary nice..........is the foil on bouth sides?...look to be free hanging?.......one thing I never got to hear was the two sided Apogee Stage 26" ribbon.......
I gess it would have gave more image hight....but was on mylar not capton so it could get hot an fail...but not minny did.... so I have read...........but who knows
thanks for the pic
Old 2nd May 2015, 02:39 PM   #4
Would you share on how you attached the magnets to the steel structure? Are they glued, or do they hold themselves in place?
Old 2nd May 2015, 03:24 PM   #5
thanks for the pic
Hi Tyu, Thanks.
The ribbon is attached every 180mm to the nylon braces.
Old 2nd May 2015, 03:25 PM   #6
No need for glue once they on the pole piece they wont jump towards each other.
Old 2nd May 2015, 04:33 PM   #7
For give me..............but I though that had to be glued??
My point is that the apogee 26" has a open spot at the top an bottem of 1 1/2"....an that I could add magnts if I wished... ....
thay did this on later 26"ribbons to get more output?
with the magnets just holding there self.... I could see if I like the sound...if not I could just pull the magnets off......
Old 2nd May 2015, 05:00 PM   #8
Tyu no Glue required.
Old 2nd May 2015, 10:53 PM   #9
Any idea of the sensitivity of the ribbons? I have some Apogee Centaur Minors and other than somewhat low sensitivity, I love the sound of the ribbons.
Thanks for sharing your project.
John
Old 3rd May 2015, 02:45 AM   #10
Hi John, T
Thanks they are very close to 90db they are easy to drive.
Brian
An "O3" - 35% smaller SMD RS O2 headphone amp version agdr Headphone Systems 17 22nd September 2014 02:12 AM
ST-35 First Build milsman2 Tubes / Valves 44 23rd May 2012 09:39 PM
10" MTM with NeoPro5i Ribbon - Build Thread opc Multi-Way 128 30th August 2011 10:16 PM
ST-35 Build Using PC13 Boards Questions and Thoughts atwageman Tubes / Valves 3 12th November 2009 06:50 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
