| Planars & Exotics ESL's, planars, and alternative technologies |
#161 |
Oh hey I did an experiment this weekend, gutting a few horns.
The horn in a crappy speaker is a regular paper tweeter say its 2" OD and the dust cap is 1/2 inch OD, the horn starts out @ 2" and rapidly contracts to 1/2 inch in the "throat" and then it flares into its rectangle outlet. I suspect its a way to reduce dispersion from a near 180 degree to a 30-45 degree there by increasing its power. In a high end speaker, its a compression driver (presumably built out of different material than paper but similar construction) that is coupled with a horn that is a little less drastic at the face that bolts to the driver. I dunno how it would play out on my design with the side ways amt ... but I have seen enough to want to try. The 45 degree one will be my first choice. Easy to build. If it sounds awful, its easy to drop it and forget it. Cool. Srinath. |
#162 | |
Custom Title
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#163 |
The trick really is to get it to not occupy the same air space - ever.
Reflect it into the room with a 90 degree spread. I dunno, easy to experiment, I get steel plates from my friend and wend them in a V shape and plonk it there and move the heil into it. See how it works. Cool. Srinath. |
#164 | |
Custom Title
Summation like you're expecting only works over a limited range of frequencies, and that with a delay on one side of the transducer. Review tapped horns for a similar idea. If not for the pathlength on the rearwave, they'd not sum positively.
#165 |
I hadn't counted the woofer's phase. Damn.
Cool. Srinath. |
#166 |
Custom Title
Some work on these... the render shows the intrusion of the rounded portion into the path. All told I should have done the whole thing with kerfs, it would have been easier. Too late now.
#167 |
Custom Title
oops missed attachment- it's hard to tell but the continuity between horn and heil is very good.
#168 |
Custom Title
| Air Motion Transformers (Heil's) and New Diaphragms | EchoWars | Planars & Exotics | 156 | 15th May 2012 01:56 PM |
| Mundorf air motion transformers on ebay | audioartspeaker | Swap Meet | 0 | 20th November 2007 08:07 PM |
| Page generated in 0.09115 seconds (83.37% PHP - 16.63% MySQL) with 11 queries |
