Mounting HiVi RTC1-A Planar Tweeter - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 5th August 2014, 02:22 AM   #1
Default Mounting HiVi RTC1-A Planar Tweeter
Can anyone tell me the correct cut-out to mount the HiVi RTC1-A Planar Tweeter?
PE says 3.52 inches dia. but that is not possible.
According to my measurements a cut-out would have to be 89.5mm X 125mm. or the gasket will not contact the cabinet. There are 2 (two) rectangles projecting above the gasket by 5mm EACH. The largest rect. is 89.5mm X 125mm.
What about the electrical connectors?
Please see pictures.
Any ideas appreciated. I am unable to get a correct answer from P.E. or Swan.
P.S. P.E. states the crossover point is 3kHz. Swan in all their literature require AT LEAST 4.5kHz crossover.
Old 13th August 2014, 12:45 AM   #2
Michael Chua's Avatar
Swan is correct. I had to use 4.5kHz. That's the lowest it can go.
You can find more information here - "ORIOLE"
Mike
AmpsLab.com
FS: Lot of HiVi F6 Woofers and Dayton PT2C-8 planar tweeters Virpz Swap Meet 5 31st December 2013 11:12 AM
HiVi Planar Isodynamic Tweeters otto88 Multi-Way 12 6th July 2011 03:42 PM
Strange coaxial tweeter from Swans/HiVi Snickers-is Class D 1 19th July 2006 07:02 PM
Most little planar tweeter wanted inertial Multi-Way 0 6th September 2005 08:51 AM
planar tweeter joz Planars & Exotics 0 31st March 2003 04:25 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
