Oh oh...
I bought 8 pannels second hand, washed them 'as usual', and discovered 'holes' in the lower area of the coating. I can see through the diaphragm, two nice windows about 1 to 4 cm in diameter. First time for me...
I checked the HV with my probe : there is no more conductivity/HV in that area...
I repaired one of them with a silver liquid made for the auto's glass heating system repair... Works -the HV comes back in the repaired area-but I've not any confidence in the robustness of my repair, and the resistivity of this product is almost zero...
By 'luck' the area is close to the side of the pannels so I can remove the wires for any surgical intervention ...
Any idea ?
PS : I'm suck at computer, and could not post any picture on the forum. Look bellow for the location of the defects. Same location for all damaged pannels.
************************************************00********
************************************************0000******
*************************************************0********
***************************************************0******
*************************************************00000****
************************************************* 0000*****
***************************************************0 ******
Any idea ?
I have Acoustat panels with 1" holes....that still work great... cant hear any diff.. an thay dont get biger......
less there Big.....play frist see if you hear...the fix my be wrose than playing with the holes....
i have had over 20 Acoustat panels in 30years....these panels are Vary hard too Kill.....i just pik up panels when i can.............good luck
Long live Acoustat panels...................
Hmmm...that's the first time that I've seen the coating come off an Acoustat panel. Based on your photo, it almost looks like some of the coating was removed by means of a solvent, rather than losing adhesion to the substrate. I wonder if someone tried to clean the panel with a solvent, or a solvent got spilled/splashed on the panel. Who knows...many years have passed since its manufacture.
In any case, any attempts at repair will likely result in a worse problem. Using any sort of metal-bearing liquid as you described is not a good idea and is very much the wrong resistivity - it could even lead to arcing in that area.
As Tyu suggested, listen to the panel first. Although certainly not perfect, the defect may be hard to detect, especially if the panel is with a larger array of panels.
I don't think there would be much of an issue.
As long as you can get it in there to wet the diaphragm you might be able to get in there with a small brush to spread it around to coat the bad area.
Due to the construction it would be difficult to make a bridge that would cause any leakage to the stators that are heavily coated with PVC.
You can also spray it into a small container to use for coating with a small swab of some sort and this would cut out any chance of overspray getting anywhere that it should not need be.
FWIW
jer
FWIW
jer
As Jim powers from ML told me in the 90s .............thay never wash panels....thay use 30-40lb compresset air .... but most people dont have air....so wash ....why not ML sales panels....
Jim,s not makeing any more Acoustat panels!
i did wash my panels but i stopet.....like this panel the coating well come off now that the panels are older..... 5kV 24/7 for years...in the heat....cold...wet.....this is what i found.....
I stopet because i would rather have a working panel than a cleaner one.....with less output
this is not all crud in the pic....the dark is some coating
long live Acoustats....................
... Thanks for the precise answers. I could not to find the Licron Crystal in France, so I keep on looking for and otherwise will have ship it from the US. Sadly I already applied the 'silver coating' in the damaged areas.
The Spectra 44 work nicely. All the mods done, -including the heavy and rigid frames- gave to them dynamics which make them sounding a little less 'ESL'. Result is good, in the 15/20 k$ range would I say. I also modified the louvre so it is less directive. Works good too.
I also damaged a pannel while trying to glue a defective HV wire.... The wire is now glued to the diaphragm. This pannel I will sacrify (!) and try to change the diaphragm with the infos given by M.James. I'll give you news ....
Mathieu
Mathieu
... These are the steel reinforcements which were later added to the frame.
=> 3mm thick stell plate, laser cut, CNC bent from 3D data, epoxy glued.
! Great improvement !
Vary cool..........adding mass well give improvement in the bass.. but is it needed?..
One subject I have never seen....with Acoustats is the almost perfectly vertical....setup of the 1+1s an 2+2s....an all the Spectra speakers...........
I have got better sound an more output of the panels.. with all of them tilted back from there almost 90 degrees.... to 60-80 degrees. back..........
It the louvers of the panels......if there at 90 degrees you only hear the output at the point..... were your ear hits the most open square louver......I found this out in the 90s with a pr of 2+2s.....also found that I got no advantage in the hight of the stack panels...........sure I feel ...interfaces work better with more panels to drive... stacking makes the foot print smaller but.....to me the panels always sounded better 12-15" off the floor.....without the floors Bass reinforcement....
sound is less boomy.....an one thing I have never found lacking was bass from Acoustats..........As long as 3 panels per speakers are used......
But the best sound after over 30years of having Acoustats .....are 3ea 9" panels 15" off the floor flat!..............that way you get all the bass needed...best image...most output...as long as the at about 80 degrees back....an you can move your head an you do not get image shift!...........
There sound like a 27"wide 1+1.....With great bass..............
All just one mans finding..................
- Planars & Exotics
- Acoustat diaphragm - damaged coating - Repair
