Back to Acoustat 1+1's after 13 years of SET and Horns - Page 5 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 26th April 2014, 06:22 AM   #41
lpd is offline lpd  Canada
I'm using an FM Acoustics 600A on my Xs with fantastic results.
Old 26th April 2014, 01:29 PM   #42
john65b is offline john65b  United States
john65b's Avatar
The H2O is a 250A ICEPower Module with a linear power supply (monster tranny, rectifier and nice big reservoir caps - not unlike like a Class A amp power supply) as opposed to a SMPS that are in the ASP series....
Whoops, I meant a and ICEPower 500A Module not a 250A...I may build one with the monster Linear power supply to try it out...
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 26th April 2014, 02:26 PM   #43
I pull out my most powerful tube amplifier in my collection: 845 Parallel push pull amplifier, 100W pure class A to power the Acoustat/Tad2001/horn system. Plenty power to drive the 2+2 with authority.
Unison845
Old 26th April 2014, 03:49 PM   #44
DeltaStar's Avatar
JohnB65, Apogee Scintilla 1 ohm burnt out a few Krell S250 in thier day, my H20-S250 being going strong for 6 yrs now , and Acoustats are a lot easier to drive than Scintilla's.
Old 6th July 2014, 08:06 AM   #45
bsy020 is offline bsy020  Israel
Default Really one of a kind
Those are very impressive monoblocks. Great piece of work.
May I ask which OPT model did you use?
I searched the tamura catalog and all their OPTs are rated for 500V DC.
Also what brand are those rectangular paper in oil capacitors?
Old 7th July 2014, 11:51 AM   #46
john65b's Avatar
Delta,
So it was not a Krell KSA-250? Only the MDA/KSA would run that 1 ohm load happily, all others likely would not last very long.
Old 7th July 2014, 09:33 PM   #47
EStat is offline EStat  United States
Originally Posted by blgtrio View Post
Hello to everyone. After 13 years of several horn and SET rigs I decided to go back to Acoustats which I enjoyed from 1986 to 2001. I had both Acoustat 2+2's which I sold and Acoustat 1+1's which I kept.
I'm a long term Acoustat guy as well beginning with the model X in '77. Went to Monitor 4 and eventually to 2+2s which I used for slightly over twenty years. Honestly, I got tired of the head-in-a-vise imaging and replaced them with Sound Lab U-1s. Two years ago, however, I found a pair of 1+1s cheap, for the garage system. I replaced the socks with new spandex ones and recently had Roy Esposito rebuild the transformers. That really opened up top end resolution. While they aren't as efficient and don't have quite the bass extension of the 2+2, I think they image better. A powered sub supplements output below 50 hz.
I wanted to get some opinions on some of the high current amps that you would recommend with the 2+2's. ..Any other insights would be appreciated.
Other brands to consider are Threshold and Pass Labs as they are specifically designed to handle reactive loads. I've been using a Stasis 3 with Acoustats for over thirty years.
Back Loaded Horns HELP! dhunte21 Full Range 4 25th November 2013 01:27 PM
In-the-Wall Back Loaded Horns howardg Full Range 80 25th September 2013 12:11 AM
Where to start for back loaded horns torea Full Range 24 12th July 2013 09:54 PM
Back Loaded Horns Helmuth Multi-Way 145 18th April 2012 10:03 PM
The Best Program for Back Loaded Horns Patrick Bateman Full Range 2 21st December 2009 04:04 PM
Copyright 1999-2017 diyAudio
