Apogee and Magnepan woofer panels - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 25th January 2014, 01:35 PM   #1
john65b is online now john65b  United States
john65b's Avatar
Default Apogee and Magnepan woofer panels
Hey all, just noticed that magnepan and Apogee woofers panels are a bit different in their placement of conductor - Magnepan has conductor wire directly between the N-S magnets, while Apogee has centerline of the ribbon conductors directly over the edges of the N-S magnets.
I would guess that Apogee design not having the ribbon conductor centerline directly between the N-S magnets would compromise their performance, and make it non linear?
See pics...
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 25th January 2014, 01:48 PM   #2
a.wayne is offline a.wayne  United States
Sin Bin
Apogee's were superior sounding in every way , they were sued by Magnapan for patent infringement and Magnapan won. Both setups with mags on one side would suffer from NL, (maggie) current , push pull setup is superior in regards to NL ....
Old 25th January 2014, 02:03 PM   #3
john65b's Avatar
Yes, I agree a Push-Pull would be ideal, but maggies and Apogees were more like Push-Don't Push? I was referring to having the conductor directly between the poles as opposed to a bit off to the side...
Anyway, Magnepan sued Apogee over the Diva True Ribbon Tweeter design, I don't think anything else was in question...
What would be lost/gained if instead of a ribbon on Apogee panel, you had an Aluminum wire like magnepan?
Old 25th January 2014, 02:28 PM   #4
tyu is offline tyu  United States
So was the Diva True Ribbon tweeter.....free hanging??... like all others Apogees..........YES!
Magnepans socaled true ribbon is tacket down evey 4"s....i hear an see a big diff. in the setups...but i gess foil is foil............
I have Maggy here an there a lot of fun...but there in that 75-80% at best to full ribbon or ESLs....but there not even close to the any Apogee............
Old 25th January 2014, 03:13 PM   #5
DeltaStar's Avatar
I wouldn't call it a true hanging ribbon, it is glued to a foam dampner about every foot and half or so.
Old 25th January 2014, 03:42 PM   #6
Sin Bin
I thought the new Maggies were push/pull ...?
Edit: nope i was not able to see if so from their website , IMO the apps had superior bass , with more drive with magnets behind, you will get more of a twisting motion the way maggie has them ...
Old 25th January 2014, 04:37 PM   #7
john65b's Avatar
The 20 series are push-pull (have perforated sheets on both sides of the diaphragm), but the 3.x and 2.x and 1.x series are still all push - don't push.
Old 25th January 2014, 05:38 PM   #8
Sin Bin
Ok, thats what i thought .....
Old 25th January 2014, 08:28 PM   #9
john65b's Avatar
Hey, I have been thinking about the Apogee Buzz and have a theory...
I think the buzz is from the speaker being over driven - look at this way - Kapton shrinks as it gets hot - I have read 8% in 15 minutes at 70C (155F). Now I have put my hands on ribbons and they can get pretty toasty - when the Aluminum gets hot it expands, while the Kaption shrinks, bowing the ribbon. Once cool, the aluminum returns back to normal, while the Kapton remains shrunk. This bowing appears as wrinkles that I think can cause the buzz more than the sides slapping on the blocks when the foam disintegrates.
What do you all think??
Old 25th January 2014, 10:30 PM   #10
WrineX is offline WrineX  Netherlands
WrineX's Avatar
Only midrange panels of high end magnepan are push pull. Not the bass! The amount of air that should pass the holes is to high any way or dampening to high. Maggie is using the resonance to extend low freq.
Apogee Centaur Woofer upgrade Rozz Multi-Way 26 16th November 2015 06:43 PM
Anyone making Apogee bass panels ? artm Planars & Exotics 74 18th August 2014 01:10 PM
Magnepan Tympani Bass Panels john65b Swap Meet 3 12th September 2012 04:59 PM
Any thoughts on mixing magnepan and apogee? martyh Planars & Exotics 4 25th February 2010 11:27 PM
Apogee Major woofer repair ledroit Planars & Exotics 1 3rd January 2010 03:32 AM
Copyright ©1999-2017 diyAudio
