Martin Logan Aerius i HT Board Transformer Kaputt !? - Page 2 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 26th September 2013, 11:47 PM   #11
Andersonix's Avatar
The original transformer supplies both 260VAC to the bias supply and ~11VAC to the music sensor turn-on circuit, and is soldered to the pcb, so finding an exact replacement is unlikely. But I expect if push came to shove, the separate voltages could be obtained from other suitable transformers mounted off-board. I would want the L and R speakers to have the same 'update' for my own sanity.
Old 26th September 2013, 11:55 PM   #12
Andersonix's Avatar
Alan, definitely take bolserst up on his offer to order transformers from ML. (Get two, as the other side is the same age.)
Old 27th September 2013, 04:25 PM   #13
thanks for all the help guys, a couple of pm's sent :->
Old 28th September 2013, 11:13 AM   #14
diceman is offline diceman  United Kingdom
If the transformer has 2 windings and one being for the auto power up the regular aerius boards I have are unlikely to be suited as they did not feature the auto power up at all.
Old 28th September 2013, 02:05 PM   #15
Not sure about the question - will check later.
I am note sure if my speakers have auto on ?
What is the part no of the boards you have ?
Maybe someone here can advise on Aerius v Aerius i ?
Old 28th September 2013, 02:42 PM   #16
Board no. MLPS-102
Pic :- Click the image to open in full size.
Old 29th September 2013, 10:16 PM   #17
bolserst's Avatar
Your board does appear to have the auto on-off circuit.
Schematic and board pic was posted here for the SL3 which looks very similar to yours.
ML SL3 intermittent bias supply problem
Old 30th September 2013, 10:04 PM   #18
Hmm,
Interesting - These were just badged as Aerius and not "I" although they are a late pair of Aerius.
Old 7th October 2013, 08:28 PM   #19
UPDATE:
Now have an older MLPS-102 from an Aerius and have connected it in place of the MLPS103 rev h on my Aerius i
Problem is the connections to the X-OVER transformer are not the same on both.
On the 103 there are 4 wires to 4 different PCB terminals, on the 102 there are only 2 wires and only 2 terminals to connect to.
On the 103 3 of the 4 are actually connected together via PCB track which is not connected to anything else on the PCB and the other is connected to a series of 15Mohm resistors.
On the 102 one wire also connects to the 15M resistors but the other is connected via a 15M resistor and then ground.
My first instinct was to simply connect the 3 wires from the 103 together into the one terminal that goes to the 15M resistor but I am worried I might damage the board.
Will post pics soon to be clearer.
Any initial thoughts ?
PS
The transformer has exactly the same readings on both 103 and 102 boards so don't think that's my problem any more that's why I switched the whole board.
Old 7th October 2013, 09:21 PM   #20
The other difference of note is that on the 102 the mains power has a ground cable connected but on the 103 it does not
Martin Logan Aerius i panel removal servasol Planars & Exotics 13 7th June 2016 11:41 PM
Recoating Martin Logan Aerius Panel FPN Planars & Exotics 40 27th January 2014 07:19 AM
Martin Logan Aerius fuse Sandor Planars & Exotics 1 29th June 2013 10:09 AM
Help Martin Logan janbb Planars & Exotics 6 4th November 2012 07:53 PM
Repair of Martin Logan Aerius i jorn Planars & Exotics 3 4th April 2010 04:50 PM
Copyright 1999-2017 diyAudio
