Magnet recognition - Page 2 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 14th August 2013, 08:33 AM   #11
Completely shuttered...to more than 10 pieces plus some magnetic debris...
I was lucky that others remained glued on the steel chassis and stayed more or less intact.
My best option is to send half the speaker to the chinese magnets factory and they determine what type it is...
soundofvoid
Old 14th August 2013, 03:14 PM   #12
expert in tautology
bear's Avatar
how about a picture??
probably can be determined by simple inspection, the color of the magnetic materials are usually different.
So one single magnet shattered??
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 14th August 2013, 03:18 PM   #13
Default Infinity EMIMS
To the best of my memory, both the Infinity EMITS and EMIMS used Samarium Cobalt magnets. It was featured in their advertising at the time. I have some EMIT plates, but no EMIMS. The magnets did tend to dislodge and shatter if the EMIT was dropped on a hard surface. Never took an EMIM apart, I think those were sent back to the factory for repair. Our service center replaced many an EMIT diaphragm, though.
Old 14th August 2013, 03:28 PM   #14
expert in tautology
bear's Avatar
If you search on these terms you will find your answer:
infinity emim repair magnet neo
They appear to be neodymium.
There is some discussion of failure modes for the magnets, magnet glue and corrosion.
_-_-
_-_-bear
Old 14th August 2013, 06:22 PM   #15
Yes in EMIM they used sam/co magnets or neo.
But the LEMIM is a MUCH bigger driver with a LOT MORE magnets.
By simply trying to put the speaker back together the repelling force
doesn't seem so intense...as if when rare earth magnets repel...
If it is neo it must be a weak neo...below N40...i don't know...
I will need to find me an expert...
soundofvoid
Old 14th August 2013, 07:41 PM   #16
Greebster's Avatar
Date of manufacture? I'm thinking samy's not neo's
Old 15th August 2013, 10:05 AM   #17
Late '90s...around '95 to '00...for the last pairs...
I have in my possession a similar driver (FS41RP) made by Fostex.
It's part of the legendary RP series (7RP-21RP-41RP).
This is a bit older but superbly made and has more or less the dimensions and
frequency range of the older (Beta-Gamma) L-EMIM.
In that one i know for a fact that sam-co magnets were used.
The Fostex description of the speaker clearly states so.
I have looked through every page in the Infinity white paper for the Epsilon
and although a detailed description of the foil is given, there is not a single word
about the magnets nature...
Given the fact that the sam-co magnets only advantages over neo is the higher temp tolerance (not an issue in our case)...their non corroding surface
(something that has been an issue in older designs) is the only reason to choose such an expensive solution.
I can verify that in both these speakers (FS41RP and HE L-EMIM) the surface of the magnets stays clean and uncorroded (whithout any coating)
after all those years...which is a testament of good design.
soundofvoid
Old 18th August 2013, 08:51 PM   #18
Greebster's Avatar
efharisto para poli
Best friend is from Kalamata
Old 19th August 2013, 08:57 PM   #19
Well...it may sound strange but i am originated from the same area too!
I actually lived there till the age of 10...then moved to Athens...small world!
soundofvoid
Old 19th August 2013, 10:44 PM   #20
Greebster's Avatar
Very small world!
In another forum I have another 'friend'. We've known each other for 16 years now. One day I asked if he was related to Alexander Dumas, author of the Three Musketeers. Yes, his great uncle. Well his great uncle knew my grandfather and gave him an authors edition of the book, which I inherited. Never met either (my grandfather or his uncle), but indeed shows how small this world is truly is
Yes I do believe in 6 of separation.
magnet design 101 - saturate iron with a ferrite magnet? capslock Multi-Way 18 28th April 2010 05:51 AM
Speaker driver recognition Radioman62 Multi-Way 3 13th February 2010 07:12 PM
Box-tuning magnet-to-magnet construction Mr_Oasis Full Range 21 2nd June 2009 01:51 AM
disc recognition problem elaar Digital Source 5 3rd September 2006 01:30 PM
DIY Iowa results and recognition (very long). jholtz Multi-Way 6 26th October 2004 04:04 AM
Copyright 1999-2017 diyAudio
