Closed-Loop Amplification with Driver Cone Position Fedback
the problem with such photo-sensors would probabely be to achieve a sufficient dynamic range -or, the other way round- sufficient resolution.
This is true, one must be concerned with resolution. But I have seen some recent data that seems to suggest that these photoresistors are quite linear for the middle 90% of their range. This is why I proposed an overlapping array of 2 or more columns/rows. This should help to average out the nonlinearities and provide increased resolution.
Light has some nice qualities (light weight, fast...) and easy to speculate about using it. But the complexities of controlling it in a highly linear fashion (linear enough to reduce the distortion of a driver) and tied perfectly to the motion of a vibrating piece of cardboard that can move an inch in-and-out, are very great.
Ben
CharlieLaub
CdS photoresistor detectors are too slow...35mS typical rise time or more.
Had an idea last year...wedge sliding across an OPT101
PHOTO DIODE SIZE: 0.090 x 0.090 inch
Enough light and a fast bandwidth...low gain.
Have not tried it yet...need to find my micrometer for measurement.
It is on the list.
