Closed-Loop Amplification with Driver Cone Position Fedback - Page 3 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 1st July 2013, 11:32 PM   #21
jcx is offline jcx  United States
depending on radiation condition velocity or accel are more nearly proportional to SPL
both near/far field and intentional cone breakup/frequency proportional decrease in radiating area are in play
but position isn't important to sound production - just keep the average centered in the gap
Old 1st July 2013, 11:56 PM   #22
xrk971 is offline xrk971  United States
xrk971's Avatar
So a soundwave that a mic records and what we want the amp and driver to reproduce are not dependent on position? I argue that position x(t)=function of time is the fundamental parameter to measure because amplifier current drives voice coil position - I think they are a linear relationship and it is their nonlinearity that produces distortion. From position as function of time we can get velocity or acceleration. So we are trying to correct for the distortion by measuring position for error correction.
Old 2nd July 2013, 12:56 AM   #23
DUG is offline DUG  Canada
I would think so.
I rejected using an accelerometer for sensing because of the integration(s) required to get position.
It would be fine for sine wave vibration testing (which I did for 12 years in a test lab) but not for music! (IMHO)
I would like to see the results using a "burst" waveform using an accelerometer as feedback.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 2nd July 2013, 01:18 PM   #24
http://www2.ece.ohio-state.edu/~schn.../subwoofer.pdf
I have built several as i stated before... its working wery well!
Old 2nd July 2013, 02:12 PM   #25
xrk971's Avatar
ESL,
Very nice paper - nice work man! Ohio State has some good stuff! My google search did not catch this and I am glad you pointed it out. This is exactly the info I was looking for. I am really surprised by how well the piezo accelerometer output tracks with SPL (Fig 3.3.1). What is the mass of the piezo element and can it be made small enough to work with a 4 inch full range driver with a typical Mms of 4 grams?
X
Old 2nd July 2013, 02:29 PM   #26
tyu is offline tyu  United States
Thanks esl 63 for posting the bass sevo paper........Can you say what res.an cap was used in the Zobel??
Old 2nd July 2013, 03:11 PM   #27
SY's Avatar
Originally Posted by DUG View Post
Counting fringes...yes...I would like to see the circuit to convert that to a linear signal.
It's a lot more convenient to process things digitally, then output the "final" analog version. In 1985, this took several large boards in a rack, these days, it's easily done in real time with a microcontroller and ADC/DAC.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 3rd July 2013, 06:34 PM   #28
You can use one extra voice coil as well...
But my experience is that a piezo tweeter works really really good!
http://www.macaulayaudio.co.uk/roaring%20sub.pdf
student project with accellerometer:
http://www.ti.com/corp/docs/landing/...ch_LaBella.pdf
Here is a study which is interesting.
Well i have some circuit design to share that works really good.
send me a PM
Old 3rd July 2013, 06:35 PM   #29
Sorry here was the link...
http://cogsys.imm.dtu.dk/nonlincomp/Klippel.pdf
esl 63
Old 4th July 2013, 02:25 AM   #30
xrk971's Avatar
ESL,
Thanks for the link on the dual voice coil technique with one serving as the transducer. Very clever, but it only gives signal when there is motion - kind of like the accelerometer. It is nice because it is easy to fit an extra sensing coil in a driver as the sensing one doesn't need to have as many windings to produce drive power. I am surprised that there is not a commercial implementation of this yet. Or is there and I am not aware of it?
How is closed loop voltage gain chosen? Dan Moos Solid State 5 13th June 2013 01:42 AM
Closed loop stability help needed. TheGimp Tubes / Valves 58 24th December 2011 01:15 AM
LTSpice, Closed loop gain? Neutrality Software Tools 8 17th August 2011 08:16 PM
Determining cone position Jrz126 Subwoofers 2 24th July 2007 03:22 PM
Opamp phase shift - open and closed loop. Circlotron Analogue Source 8 23rd April 2003 07:06 AM
Copyright 1999-2017 diyAudio
