Martin Logan CLS membrane re-do - Page 4 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 18th June 2013, 07:50 PM   #31
john65b is offline john65b  United States
john65b's Avatar
I beleive the original Mylar thickness was 6 microns, so cannot be thicker Mylar.
Are the stators clamped tight?
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 19th June 2013, 09:46 PM   #32
audioquestM-40's Avatar
Exactly what I used and they are tight all around
Krell KST100, Edge M4, Bryston .5b, Audio Research LS2B, OPPO 103, Moon 300d, MF A3.24, Oracle Alexandria SAE mc cart, Jasmine LP 2.0se phono, Martin Logan reQuest
Old 21st June 2013, 12:09 PM   #33
john65b's Avatar
Add another coating of Licron?
Old 2nd November 2013, 03:12 AM   #34
john65b's Avatar
Hey AQ,
Did you finally find the issue of dull sound?? Charge Leak?
Old 3rd November 2013, 04:04 PM   #35
Default DS Tape Sticking
Re: long term "sticktion" of DS tape, pay close attention to Jazzman's diagram showing how the DS tape extends beyond the edges of the stators and is wrapped over the edges and taped down with polyester tape. I didn't notice Charlie changed his original procedure until recently and consequently I am working on my fourth rebuild now (the other three failed due to tape not adhering to the stators.) The DS tape will not hold the Mylar tension unless it is wrapped over the edges. I also have noticed the tape stuck much better to stators coated with Rustoleum gloss black as a final coat, rather than gloss clear coat that I currently use. After the panels are completed,I will clamp them to new maple frames I have built. This should help to insure the ESL panels don't pull apart. HTH.
Old 3rd November 2013, 05:43 PM   #36
CharlieM's Avatar
I should add and clarify:
My second generation panels, which I am still using, still has the foam tape merely overhanging the stator edges by 1/16", followed by over-wrapping the edges with 2-mil polyester packing tape. This arrangement is still holding tension on the diaphragms 5 years later so it does work-- but it might not have worked if the foam tape were not fresh (good tack) when applied, and/or if the diaphragm coating were not solvent cleaned to promote adhesion to the tape. Some paints have more surface energy than others, which helps adhesion.
I decided to recommend using wider foam tape and wrapping it over the stator edges for two reasons. First, it should hold diaphragm tension even if the foam tape doesn't stick all that well to the stator.
Secondly, a conversation I had with our friend Steve (a.k.a. Bolserst) lead me to believe that the high dielectric-strength polyester tape may actually reflect and focus the corona back onto the stator edge (and possibly breaking down the stator coating). It follows then, that by first wrapping the stator edges with the lower-dielectric foam tape, followed by polyester tape over the top, the corona would not be as intensely reflected back onto the stator edges... yet the corona is still confined enough to prevent arcing to the opposing stator.
I actually have not built a panel with the wider foam tape wrapped over the stator edges as shown in my updated sketch, but if I ever have to redo my panels, this is how I will do it. I might even use 1.5" wide tape and wrap a full .75" over the stator edge. And it may be easier to get the foam tape to stick to the outside of the stator if it were wrapped over the edges before tensioning and bonding to the diaphragm (the excess diaphragm would then be wrapped over the stator edges after tensioning). In any case, I'm now convinced it's better to wrap the foam tape over the stator edges.
Old 31st January 2014, 06:24 PM   #37
C.A.P is offline C.A.P  United States
Great thread I would love to hear feed back on sound and such as my CLS are dead or LOW
Martin Logan CLS Power Supply john65b Planars & Exotics 63 28th December 2014 04:07 AM
Martin Logan CLS - Frame Dimensions john65b Planars & Exotics 9 5th April 2013 11:43 AM
martin logan cls Williams Audio Planars & Exotics 1 4th October 2012 09:38 PM
Martin Logan CLS panels for sale td358 Swap Meet 2 30th December 2011 03:38 PM
FS - Martin Logan CLS Panels nautilus Swap Meet 3 18th December 2007 11:35 PM
Copyright 1999-2017 diyAudio
