Series-Connected Single-Ended Output Transformers in ESL - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 22nd May 2013, 06:29 PM   #1
Default Series-Connected Single-Ended Output Transformers in ESL
Are there any drawbacks to substituting two single-ended output transformers (as pictured) for the typical push-pull arrangement in an ESL? I would avoid this sort of thing in a tube amplifier because the bias current would still cause the cores to saturate, but since there is no current flow in an idling ESL, I can't see an issue. Am I missing anything?
Thanks,
Nick
Old 22nd May 2013, 07:43 PM   #2
bolserst's Avatar
Nope, nothing wrong with your idea.
Quad, Audiostatic, and a few other manufacturers use this technique as do many DIYers.
Usually the primaries are put in parallel rather than series to get higher step-up ratio if primary turns and core area are adequate for operation without core staturation to the LF bandwidth desired.
Quad ESL-63 circuit attached below.
Another alternative for single-ended transformer use is a virtual center tap:
Antek Toroidal power transformer for Step-up, Measurements (part 1/2)
If leakage inductance is low enough you can even use 4 transformers in series-parallel combination:
DIY-
Jazzman's DIY Electrostatic Loudspeaker Page: The Electronics Package
Audiostatic-
Long throw ESL
Old 22nd May 2013, 07:57 PM   #3
Much obliged!
Old 22nd May 2013, 09:28 PM   #4
AcoustatAnswerMan's Avatar
I agree this should work okay, assuming suitable transformers. It also has the added advantage that each transformer is subjected to only half the voltage that would be seen by a push-pull transformer.
This very technique was used in Acoustat's full-range Spectra series. Two identical transformers have their primaries connected in parallel (but out-of-phase), with each secondary driving one stator. This resulted in a much more reliable transformer, and I am not aware of any Spectra transformers having a high-voltage failure. The same could not be said of Acoustat's earlier MK-121 series speakers, where the push-pull transformers are subjected to the full peak-to-peak voltage. Those transformers can arc-over if overdriven, despite improvements over the years (i.e. the Medallion transformers had better arc-over protection than the original design).
Old 24th May 2013, 08:29 AM   #5
Banned
Sure there are drawbacks: the impedance will be lower.
Till so far any Antek or other "simple" toroidal transformer is not capable for the low frequency range. Many other esl transformer too and most have impedance problems if used full range.
Thanks,
Nick
Old 27th November 2013, 11:39 AM   #6
Sorry to drag this up, may I ask what is probably a really, really dopey question. Is it possible to connect the secondaries of two output transformers together, if one is single ended, and one push pull?
I'm hoping that the issues with the air gap etc are all confined to the primary. I'm trying to drive the same speaker(s) from an amp with two power amps.
Old 27th November 2013, 03:22 PM   #7
Banned
Sure it is possible but at a cost: more difficult to drive because impedance will be low. And because of that, frequency response is less good, distortion higher. And last but not least: efficiency is lower.
A real good esl transformer has less problems overall but also at a price: its more difficult to to make so it cost more money.
Old 28th November 2013, 02:38 PM   #8
tyu is offline tyu  United States
a pic..............may help.......
FS: PLITRON single ended output transformers Redboy Swap Meet 5 11th November 2012 04:32 PM
Wanted: Lundahl 1620 single ended output transformers tronan Swap Meet 0 9th February 2011 07:17 PM
WTB: Single Ended Output Transformers Zedguy Swap Meet 2 2nd August 2009 02:05 AM
Black Art Single Ended Output Transformers DVDHack Tubes / Valves 2 11th January 2004 04:02 AM
Using PP output transformers for single ended amp SHiFTY Tubes / Valves 4 26th August 2002 07:18 PM
Copyright 1999-2017 diyAudio
