is a Dipole exotic? - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 4th May 2013, 10:37 AM   #1
Default is a Dipole exotic?
If it's not maybe I should be bumped to another forum but someone else posted about dipoles so here goes. >_>
Is there anything special about dipole speakers that's different than say, having two of the same speaker mounted back to back out of phase to face forward and backwards? Like lets say I wanted to have a dipole surround which matches the mids/tweeters of other speakers, could I just use two of the same model back to back like that... or is there something else special about the output or dispersion pattern or something to keep in mind?
At least two surround configurations i've read about specifically request dipole surrounds on some but not all channels.
Old 6th May 2013, 02:27 AM   #2
Greebster's Avatar
the spacing distance between the front and back have a direct impact on freq resp including deep lobing/nulls created by phase imbalance which can be extreme if not properly implemented.
Would not suggest such
Old 6th May 2013, 04:30 AM   #3
Greebster nailed it. Spacing is everything at mid and high frequencies so your idea wouldn't work.
I bet the guys at Bell Labs that came up with the first electrostatic speaker almost 100 years ago thought dipoles were exotic.
Old 6th May 2013, 11:52 AM   #4
I know a german dipole design in which two tweeters were used. The reason was that the tweeters were closed designs while midrange and woofers were open design. So they needed a second one for dipole action. Don't know anymore which way ('polarity') the tweeter was connected. With the second tweeter the indirect soundfield will be more balanced, just like the direct sound. It measured very well.
drs M.J. Dijkstra
Old 3rd June 2013, 12:36 PM   #5
I think that dipoles exist in a different section, as they are in most parts conventional. Dipole based ideas are very popular, and should in my opinion have their own section, as you see posts on this subject in each of the loudspeaker sections.
The overlap between DIY dipoles and DIY conventional speakers is greater than DIY dipoles and DIY Electrostatics, Air Motion Transformers, Piezoelectric, Ribbon and planar magnetic, Bending wave, Digital, Plasma and NeXT based speakers.
This said this forum is a catch all for all of us who don't fit neatly into the other categories. So in Summary if I was a moderator / admin on this site, I would make a new section, and move your thread and many from the subwoofer, multiway, and fullrange forums.
Unless some one creates a new forum section, I say welcome to the chaos that is planars-exotics.
Old 3rd June 2013, 12:42 PM   #6
Oh and I would create a Horn speaker section too, Best regards.
Old 4th June 2013, 12:05 AM   #7
Andersonix's Avatar
Are you sure they weren't talking about "Bi-pole" surrounds? This might be two monopoles placed back-to-back.
Dipole Ribbon tweeter isolation from dipole mid-woofer array Bent Planars & Exotics 8 29th March 2015 09:45 AM
Not a planar (But definitely an exotic) Remlab Planars & Exotics 0 16th August 2012 08:48 AM
How much free air does a dipole line need to stay a dipole? seaspeak Planars & Exotics 0 13th September 2011 05:20 PM
exotic product ... exotic price Pocoyo Swap Meet 73 20th June 2010 02:44 AM
(WW) MMTMM dipole 4 vs 3 way / dipole benefit frequencies? charliemouse Multi-Way 25 8th July 2007 12:19 AM
Copyright 1999-2017 diyAudio
