Magnepan Ribbon Tweeter Question - Page 2 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 3rd May 2013, 03:49 AM   #11
john65b is offline john65b  United States
john65b's Avatar
The resistance laying down (19 ohms) and standing up (8ohm) was totally wrong - battery was going out on the voltmeter... actually were more like .9 ohms...luckily the amp I was using can do 1 ohm load (Innersound ESL amp), otherwise I would have smoked the amp.
I have the two 1/2" pleated runs in series (up then down) and notice in front of the ribbons the sound seems to be canceling each other out, and off to the sides of the tweeter assembly there is descent spl. I think I need to run a return wire and have both ribbons running same direction so they are not canceling each other out?? This may be obvious to all you smart ribbon people......
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 5th May 2013, 03:51 PM   #12
gootee is offline gootee  United States
Well you probably don't want to end up with them in parallel. . So maybe you could run a wire from the top of one to the bottom of the other.
Also, if you made them an eighth inch wide instead of a half inch, you would have about four Ohms.
Old 5th May 2013, 04:33 PM   #13
Yes you need a return wire to get the current flow in the same direktion.
Bernt
Old 5th May 2013, 05:12 PM   #14
john65b's Avatar
Yes, I ran a wire from top of the first to the bottom of the second, and it has very decent spl now...
I am playing with a few "variations" on the ribbons. One is to have a single ribbon twice as wide (about 1/2" wide), pleated, and "opened' into a 90 degree "V". I will likely be around .5 oms so I will have to put in a series resistor of .47ohms. Pics soon...
Magnepan MMG + Ribbon Ultima GTR Planars & Exotics 1 3rd October 2012 10:55 AM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 08:50 AM
d’Appolito / ribbon tweeter question Wseaton Multi-Way 29 17th February 2006 12:04 AM
Magnepan ribbon tweeter repair... mcelaj Planars & Exotics 2 17th May 2005 01:15 AM
what to pair with magnepan tweeter? cowanrg Multi-Way 13 13th January 2005 08:44 PM
Copyright ©1999-2017 diyAudio
