Another segmented ESL - Page 4 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 5th May 2013, 04:27 AM   #31
alexberg's Avatar
Originally Posted by golfnut View Post
If you try washing machined polycarbonate parts in an utrasonic bath they shatter into dozens of small bits - quite stunning actually.
What purpose does it serve? Cavitation can destroy almost any material. http://www.absotecthailand.com/Cavitation.pdf
I would talk to billboard or light signs companies: they do know what and how to cut glue and fix various plastic parts acrylic included.
Old 5th May 2013, 04:42 AM   #32
golfnut is offline golfnut  New Zealand
golfnut's Avatar
Alexberg: Purpose was to thoroughly remove machine oil
We had no problems with other plastics, including acrylic and PVC. Just soaking polycabonate will do damage - capilary forces rather than cavitation
Old 12th May 2013, 12:57 AM   #33
Few is offline Few  United States
Golfnut (and others),
I hope this isn't too off topic. I'm interested in implementing a similar approach in a sectioned planar magnetic driver, rather than an ESL. I'm sure there's no acoustic reason it shouldn't work similarly. Any suggestions on the best circuit topology? I'm envisioning vertical parallel aluminum conductors immersed in a magnetic field. With the foil I have on hand it's convenient to have individual conductors with resistances on the order of 1 or 2 ohms. I can run multiple physically parallel, but electrically in series, conductors in each magnet gap to increase the resistance if necessary.
Few
Old 12th May 2013, 05:08 AM   #34
golfnut's Avatar
Hi Few
I’m sorry I don’t know enough about ribbon-type transducers to be able to give you hard advice on other types of segmented planar radiators, but I can perhaps point to a few things that you need to think about. Perhaps there are some books or DIYers about that will answer some of these questions
The ESL strip radiator is essentially a constant pressure source (because the diaphragm mass is so small), whereas the traditional electromagnetic speaker is a constant volume-velocity source because it’s behaviour is dominated by the cone mass. It may be that the ribbon is sufficiently light it too can be treated as a pressure source.
A line-source, like the single strip ESL, has an awkward sqrt(f) response characteristic, which is corrected by the RC transmission line structure of the segmented ESL. If the same awkward frequency dependence applies to the segmented planar electromagnetic radiator, then it may be that there is a similar RL transmission line structure that will equalise the response.
For the ESL, the far-field polar response is given by the Fourier transform of the stator current distribution. A similar relation may also apply to the electromagnetic version. If you’re not familiar with Fourier transforms, this means that the width of the radiator must always be less than a wavelength of the sound - narrow (e.g., single strip) at high frequencies, and wide (multiple strips in parallel) at low frequencies where you need area anyway, to ensure there are no horrible phase effects as you move off axis. If you try to drive the whole panel at high frequencies, then the on axis listening spot will be incredibly narrow, and anywhere off axis will lose all phase coherence and clarity.
Sorry can’t be more helpful, can’t help thinking that someone must know this stuff.
Old 12th May 2013, 03:23 PM   #35
Thanks very much for the response. Some form of RL network is what I was envisioning. I bought what was described as 5.5 um thick Al foil and very thin polyester film so that I could get as close to an ESL's lightness as possible. Alas, I've discovered the foil is 13 um thick, not 5.5 um. Now I'm fiddling around with geometries hoping to find a way to make use of it without undermining my original goal. That fiddling has led me to wonder what my options are as far as controlling the directivity.
I don't know for sure whether I'll be able to duplicate the sqrt(f) response. It'll be interesting to find out. Your comments about the Fourier transform triggered in my mind the connection between diffraction through a slit yielding a Fourier transform (Fraunhofer diffraction (mathematics) - Wikipedia) and radiation from a slit-shaped diaphragm behaving similarly. I don't think I had quite made that link before.
Few
Old 12th May 2013, 09:24 PM   #36
Pollo is offline Pollo  Finland
Hi Few
Segmented planar magnetic speaker is doable. I finished such a construction recently. I connected the aluminum segments electrically in series and segmenting filter was done with parallel capacitors.
If you think of current drive, this provides the same electrical response as ESL parallel segmenting RC filter. Response with voltage drive is different but it does not affect the segmenting. A series L-C-R filter was used to correct the overall response.
I used 12 um polyester and 27 um aluminum which is rather heavy duty. I got barely enough high frequency output and impedance minimum is low. Your 13 um aluminum should be less problematic.
Maybe you can get more info from my web page. It's in Finnish, so try a translator.
Magnetostaattiset kaiuttimet
RL structure (inductor in series with segments) was considered but it seemed impractical:
- Series configuration: each segment would need a bypass-path for high frequencies (capacitor and/or resistor).
- Parallel configuration: total impedance would be very low. However, this would make direct counterparts to ESL parallel and ladder structures. It could be doable with very thin aluminum strips or an impedance transformer.
Old 13th May 2013, 03:59 PM   #37
Many thanks Pollo, and that's a very nicely constructed project you have there! I'm using a vertical array of open backed woofers for the bass so I'm only looking to use the planamagnetc driver down to 300-500 Hz. I was hoping for good sensitivity with the NdFeB magnets so your finding concerns me a bit. Perhaps the thinner foil will help.
Do you have any directivity measurements you could share? I think they'd be on the topic of the original thread and the comparison with ESLs might be of interest.
Thanks again
Few
Old 13th May 2013, 06:59 PM   #38
The widths of segments are 67 - 43 - 17 - 43 - 67 mm, and the total width of the speaker is 360 mm. Low-pass corner frequencies are 730 and 370 Hz for 43 and 67 mm segments respectively. There may be still some room to optimize the widths, frequencies and number of bands.
Frequency response was measured in an anechoic chamber from 0 (front) to 90 (side) to 180 degrees (back). We are not interested in the front response here because it can be equalized freely. The curves are normalized relative to the front response to demonstrate the directivity more clearly. Some smoothing was applied.
The attached pictures shows the horizontal directivity in the front and the rear. Radiation pattern is almost a figure-of-eight below 1 kHz. There are some irregularities above 1 kHz, but I have avoided strong beaming at highest frequencies. The rear responses are not as pretty as the front responses. Lower treble is peaking and higher is attenuated, which is caused by mechanical structure (magnets, perforated plate, damping material). ESL would be better in this respect.
The sensitivity was good in the midrange before I added the series filter. I had to attenuate 1.5 kHz up to 17 dB to get the midrange at the same level as bass and treble. Lighter materials should extend the good sensitivity range to higher frequencies.
Old 14th May 2013, 05:30 PM   #39
Few, In the link on post 3 I did some simulations showing the effect of dispersion vs Frequency and radiating area width.
When the width equals one wavelength it is typically a figure 8 pattern and as the frequency is lowered it transitions to a circular omni pattern.
In my design I used a doubling of width per each next section of radiating area.
Some use all equal width sections, Which one is better I do not know.
But by using the Segmented ESL simulator it shows that the more the number of smaller sections there is, smoother the field of dispersion becomes is as the frequency is raised.
The center section is driven fullrange and each next section outside of the center is driven with less high frequency's.
You probably all ready knew this but you must keep this in mind when you are configuring your sectional crossover.
I have been thinking about such a system as well.
FWIW
jer
Old 15th May 2013, 07:03 AM   #40
golfnut's Avatar
Hi Few
There are three effects that contribute to the horizontal polar response.
Firstly, all dipole radiators have a basic cos(angle) dependence in their response. This gives the figure 8 response geraldfryjr referred to. There’s nothing you can do about this term.
The second factor is determined by the width of the strips. This gives a sin(x)/x function where x=pi.f.width.sin(angle)/c. To minimise phase reversals with increasing angle at high frequencies – say up to 20 kHz, the strips should be less than about 15 mm.
For ESLs, the third factor has to do with the current distribution in the different segments. With the RC transmission line, the polar response also has a term that looks like a second order Butterworth response with angle.
The overall polar response is the product of the three terms. If you keep the strip width small and get the drive current distribution right, then you can get the polar response to be well behaved.
regards
Segmented Wire Stator ESL simulator (esl_seg_ui) bolserst Planars & Exotics 92 11th December 2016 12:13 AM
ER Audio ESL III Kit, and ESL questions in general wixy Planars & Exotics 27 30th July 2014 12:14 AM
New design for segmented ribbon tweeters Spatz Planars & Exotics 8 5th June 2013 10:55 PM
segmented panels Lucius Planars & Exotics 10 5th July 2006 08:18 AM
angles for segmented ESL? Few Planars & Exotics 21 25th February 2005 04:30 PM
Copyright 1999-2017 diyAudio
