Yet another DIY AMT - Page 15 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 13th May 2013, 09:26 AM   #141
solhaga is offline solhaga  Sweden
Originally Posted by RayCtech View Post
Then the depth of the wave guide should match the 15" - depth from front of driver (15") to where the voice coil / dust cap are mounted. My 15" cones are 100 mm deep....
But shouldn´t the wave guide depth start at where the AMT´s area is equal to the 15"´s area and not at the dust cap?
Old 13th May 2013, 11:26 AM   #142
I mean that the throat/cone of the wave guide in this case is 120x160 mm and not the area of the 15" voice coil.
The opening is still 380x380 mm though.
Old 14th May 2013, 04:39 AM   #143
angeloitacare's Avatar
If you use a waveguide instead of EQ you will improve the fidelity as the distortion will be much lower. And the directivity and soundstage improves also...
Picture shows the first prototype with AMT "midrange" and AMT "super tweeter" in a CNCed Corian waveguide, and three 8" drivers in a combined CNCed Corian baffle / basket..
hi Raymond
your prototype amt speakers looks amazing. How does it perform ? where do you cross the amt to the cone woofers ? Will you develope a bass amt later on ?
Angelo
Old 14th May 2013, 06:56 AM   #144
For a starter 50 mm should be easy for you to implement.
Old 14th May 2013, 07:15 AM   #145
Yes, but I need to vertically align the AMT to the woofer before I can do any listening tests. Now the woofers are 30 cm apart from the AMT.
But, for sure, I can do some directivety and SQ measurements first.
Old 14th May 2013, 07:41 AM   #146
Originally Posted by angeloitacare View Post
hi Raymond
Angelo
300 or 500Hz (6dB/oct series filter). Bass AMT diaphragms and parts was developed and made more than three years ago - but never assembled.. Since then a lot of new products / technologies have been researched, developed and prototypes made.. Production, marketing and sales are not my "cup of tea" and time and cash then only allows for prototypes and pre-production items for my own use...
Old 15th May 2013, 04:34 AM   #147
Frequency plots at 1 m. 0, 15 and 30 degrees.
This membrane with 7 um doesn´t go quite as low as the 10 um membrane.
Does anyone know how to make Holm show more than three curves?
Old 15th May 2013, 09:20 AM   #148
With wave guide this will change slightly and I expect a 5 to 10 degree placement (with wave guide) will give very good results..
Filtered at 200 - 250Hz and you will have -3dB at 350 - 400Hz...
Old 15th May 2013, 11:38 AM   #149
hi Raymond
are your plans to make progress with the bass amt this year ? A fullrange amt speaker will be a major evolution, if not revolution, in high-end audio......
Old 15th May 2013, 12:56 PM   #150
hi Raymond
Plans = yes, time and cash = ?
Diy AMT båndsei Planars & Exotics 779 3rd October 2016 03:56 PM
AMT diaphragm DIY basics. graeme uk Planars & Exotics 2 9th December 2010 10:17 PM
big AMT Diy Charcoal Planars & Exotics 27 13th October 2008 07:41 AM
Diy Amt ? woody Planars & Exotics 0 24th September 2005 12:17 PM
Diy Amt JohnL Planars & Exotics 4 29th April 2005 04:16 PM
Copyright ©1999-2017 diyAudio
