| Planars & Exotics ESL's, planars, and alternative technologies |
#11 | |
The diaphragm movement in the omni pressure mics is minimal, as well, and is limited to some sub-micron distances. I am not familiar how the laser sensors work. In the ESL the top end is limited mostly by the length of the front-to-back signal path. Best, M |
#12 | ||
I think there must be a significant difference between a small microphone and large area like a window glass. Pressure-like behavior can only be expected when wavelength is large compared to active area of the diaphragm(this case it is glass). When this frequency is exceeded the membrane or window glass will be receiving the pressure gradient not in phase across its area so it can not be said to be operating in "pressure" mode anymore. I could see no reason why a high or even mid range content could reach area as large as window glass in-phase with typical sound sources. Also a 50u glass is quite not a match to a typical window glass which is 3-5mm thich(thats about 100 times more). Quote:
Regards, Lukas. |
#13 |
I would agree that the mass would limit the top end output and the front to back distance will limit the low frequency response unless the back was closed.
#14 | |
The front to back distance does NOT matter as far as the low frequency response is concerned. The reason this is so is because the ESL diaphragm is just responding to the acoustic sound field it is placed in. As long as the diaphragm can be approximated as lacking in stiffness and mass, the diaphragm motion will follow the air motion in the sound field exactly, and the voltage output will be directly proportional to air displacement in the sound field at all frequencies. This is distinctly different from the far-field response of the same ESL used as a speaker if constant voltage was applied to it's stators which DOES depend on the front to back distance. The "lacking in stiffness and mass" approximation breaks down at the frequency extremes. - the top end bandwidth is limited by the diaphragm mass. - the low end bandwidth is limited by the diaphragm stiffness which resulting in the diaphragm resonance. For extended low end response you need very low tension to get resonance < 20Hz. Pressure ESL microphone: Unlike the dipole ESL microphone the top end bandwidth of the pressure ESL microphone is defined by the fundamental resonance. As such, the pressure microphone operates in the stiffness dominated regime. Voltage output is directly proportional to applied acoustic pressure and is uniform for all frequencies below the diaphragm resonance. The B&K measurement microphones mentioned in Post #3 use a metal diaphragm and very high tension to place the resonance >40kHz. @ Bazukaz, Very interesting idea using a large ESL to capture average sound field. This might be useful for avoiding response variations from room modes at LF. I may have to give it a try. All my dipole ESL microphones have been smaller than 3" x 3"(7.5cm x 7.5cm). |
#16 | ||||
...where is the flat response in ribbons coming from? In the "native" fig8 pattern the sound wave strikes the front of the diaphragm and creates acoustic pressure p1. Since the back of the ribbon is exposed, the same sound wave flows around the ribbon and pole pieces/magnet structure some distance (called acoustic path d) and creates some acoustical pressure p2 at the back of the ribbon. This results in pressure difference p1-p2, which in fact, is a driving force to move the ribbon. For example, why there is a null at the 90 degrees polar response? Because the sound wave reaches both, front and back at the same time, so there is no pressure difference. The interesting feature of this driving force is that it doubles with every octave, so the acoustical response of the ribbon actually RAISES with 6db8 rate. Now, remember that the mass controlled system naturally has a falling response? When we combine those two, that gives us an overall flat response. Now let's see what's going on on the extremes of the bandwidth. 1) Low end: Obviously, the tuning frequency of the ribbon would determine the lowest response. However, in the real system there always will be a slit between the ribbon itself and magnet/pole, so because of the viscosity of the air in that slit below some certain point the system turns into the STIFFNESS controlled one (the one, which defines true omni operation) and the response below that point rapidly falls--that's why it is not practical to tune the ribbon much lower that point. 2) Top end: As we talked earlier, there is a distance d, which represents the path between front and back and obviously this distance can be translated into the wavelength. As we talked, the driving force p1-p2 increases with each octave, but only to the point where the d represents 1/2 wavelength, because when the d reaches the full wavelength our driving force p1-p2 becomes ZERO. That is, in the condition when the wavelength of the signal becomes equal to the distance of the acoustic path d obviously the p2 will become equal to p1 (because it is 360 degree shift) and the ribbon won't be moving. That's why if we know the acoustical path d and ribbon dimensions, it is very easy to calculate the top frequency response. It is important to notice, the top response will also be somewhat affected by diffractions caused by magnet system cavity, but there are special graphs, which help to correct the calculations to the very high degree of accuracy. Hopefully it helps and puts more light on how the ribbon microphones work. Best, Mark Fouxman Samar Audio & Microphone Design Last edited by Marik; 4th March 2013 at 03:52 AM. |
#17 | |
Best, M |
#18 |
Interesting debate.
This leads to something that has puzzled me for 50 years: where are the electret speakers? Ben
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), mixed-bass Klipschorn w/param EQ plus giant OB using 1960's Stephens woofer HiFi aspirations since 1956 |
#19 | |||
When wavelength is small compared to glass size(which is true for all but the lowest frequency) different parts of glass will be hit at different times from typical sound sources so phase is not the same across the area. I do not really get what do you mean by "strictly pressure operation" under these conditions ? Also at 20 kHz 4-5 mm thick glass looks like a very hard wall with thickness equal to about a quarter the wave length(compare this to ~1.7meter@50Hz). I think in this case we must consider the medium(glass) into equation as well with its mass, stiffness etc. Also can we assume glass will be operating in stiffness mode across the entire frequency range? I have tried to bounce a glass of the door and it seems to resonate somewhere in the low midrange. Quote:
) showed that if membrane thickness is more than about 8-10 microns top end will be dropping.So perhaps the same model cannot be applied to both ribbons and ESLs or it cannot be "reversed". Also in the paper "Wide-range electrostatic loudspeaker" by Walker there is an interesting graph showing effects of stiffness, mass and radiation resistance vs frequency although no actual values. Quote:
So it should not be uniform across the area, causing induced voltage to cancel out and drop with increasing frequency. Regards, Lukas. |
#20 | ||
Thanks for sharing your knowledge on ribbon microphones. I have no experience with them, but your description of the path length limitation makes sense. I have experimented with using small ESLs (1"x1" up to 3"x3") as microphones and the top end roll off was the same for all sizes if the diaphragm thickness and % open area of the stators was the same. Perhaps the reason for the difference in behavior is that the ribbon is mass controlled so the sound wave takes the path of least resistance and moves/diffracts around the ribbon-magnet structure and develops the delta pressure to move the ribbon. The ESL diaphragm doesn't present an obstruction to the sound wave like a mass controlled ribbon so moves with the air motion rather than reacting to a pressure difference due to the sound wave going around it. Thoughts? Quote:
So, I doubt this would be of practical use in actual recording situations. But, Bazukaz comment just made me curious as to what the result would be. Imagine me trying to record a friend playing cello in a large room with an 8ft ceiling. If I wanted to place the mics at a typical listenting distance of 12ft away, the frequency balance would change depending on the height I placed the mic at due to floor-to ceiling room mode...fullest sound on the floor or at ceiling height, leanest at midpoint between floor and ceiling. The thought was if I used a floor-to-ceiling ESL as a microphone would I get a more natural frequency balance? Or, multiply point source mics distributed to average out the room mode of concern. In practice close mic placement would allow direct sound to dominate over the room modes and achieve the same result. But, close mic placement accentuates the string harmonics and makes the cello sound like your playing it, not sitting at a distance listening to it. |
| Electrostatic speakers | electros | Planars & Exotics | 23 | 26th March 2012 04:45 PM |
| Calibrating microphones and speakers | Wavebourn | Solid State | 56 | 13th June 2009 04:24 PM |
| Anyone had an experience of electrostatic speakers? | Test Electrix | Multi-Way | 1 | 16th March 2009 02:27 AM |
| electrostatic speakers | junglejuice | Planars & Exotics | 3 | 22nd October 2001 09:32 PM |
