Making an electrostatic headphone driver. - Page 6 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 16th February 2013, 01:54 AM   #51
chinsettawong's Avatar
With all the time effort you'll put into making good transformers, you might want to consider making a good direct drive amp. I really feel that a good direct drive amp sounds much better.
Wachara C.
Old 16th February 2013, 02:13 AM   #52
I've recently put together a KGSSHV amp designed by Dr. Kevin Gilmore. It sounds really nice with my DIY headphones.
Wachara C.
Old 16th February 2013, 03:30 AM   #53
Originally Posted by esltransformer View Post
The Stax measure pretty good, only frequency and fase (+ & -) response from my own is better.
Thank you for explaining "fase", is it be "phase" in english? or is it to do with the delta of phase between positive(+) & negative(-)?
Maybe i will develop a new transformer for the Stax soon. I have new HiB (M0) material and my brother has bought a Stax too so if people here are interested i maybe can reduce the research cost.
Could you explain a little more your thinking. I look at the board in front of me with 8 transformers all rated 30VA and I look at the little stax transformers and its clear a cheaper transformer solution can be made rather than using 4 large torroidal transformers.
See here a picture of my transformer
Wow its big, I guess you have made a few transformers over the years?
I am also wondering most of all how to do a better than or as good as Stax Headphone driver cheaply. The expensive but definitely good solution is:
SOWTER ELECTROSTATIC LOUDSPEAKER ESL TRANSFORMERS
sowter.co.uk ID : 4342 (or 6504)
Price : 185.44
Power : 50 W
Lowest frequency for full power : 40 Hz
Primary Z ohms: 8
Ratio 1:50 (or 1:70)
Center tapped
Input Volts : 20 (or 14.7)
Output Volts : 1000
but this makes about 400 Euro plus shipping, but it should drive all and any electrostatic headphones beautifully up to the standard of the power signal.
But At around 400 Euros before shipping, it seems a lot of money for the overkill solution, especially if the power is less than 4 Watts Peak, and cost and size of transformers
goes up with power.
I have decided to continue working my 4 per channel step up solution as it is promising, but it is inelegant in bulk.
Because it had no physical structure before it was hard to move.
Moving it onto a board meant everything had to be dismantled, it takes a lot of screwing to do this, all multi core wires are tinned with a soldering iron before attached to the terminal block. I have decided to buffer the transformers with a terminal point per winding and a separate terminal block bringing all the transformers together. this way I can switch between 2,3 and 4 transformers easily without disturbing the rest of the circuit. I guess its almost point to point wiring but bolting terminal blocks to a lump or wood is a lot easier for high voltages and you have no clue what it will look like in the end. Each experiment brings new results.
Owen
Old 16th February 2013, 04:03 AM   #54
I would definitely have to agree with Wachara on that one.
Your amp is not liking the impedance now and every time you add more transformers you are adding more capacitance.
And upping the transformation ratio only makes it more worse for the amplifier.
I am having this very same issue with my desktop ESL.
My panel little panel has only 50pf of capacitance and the four cores it takes to drive it has nearly 20 times or more as much capacitance and for my very high ratio of well over 1:150 to 1:250 my impedance some where below .3 ohms and .16 ohms at 20khz(as an example).
And I still can't get much below 300hz without running into core saturation problems using the full 40Vrms that my amp can supply.
This also means that only about 5% of the amplifiers power is actually used to create sound out of the panel and the rest of the power is wasted as heat in the transformers dielectric insulating material (at the higher frequency's) and amplifier because of the current it takes to maintain the voltage.
The money you spend on power transformers designed for 60Hz you are better off finding a surplus Tube OPT for P-P 6V6's or something for low power.
That way it will already have enough turns on it for the size of core that it is and still be able to get down to 20Hz or 30Hz with out saturating the core and it should have I decently low amount of capacitance as well to limit the waste of power at the higher frequency's.
Building a Class A P-P solid state amp that can swing 500V tp 1000V p-p is not that hard.
I have made such an amp but only for 200v so far using a dual opamp and a few FET's on my bench using a plug in protoboard.
I did it just to test the methods involved as I used single FET's and FET's stacked up in series (IRF510's) and it worked great.
I have posted my schematics in other threads and have dug up and posted many other versions including the Stax's version that uses the very same topology that I came up with on my own.
A pair of these amps is next on my things to do list only at a much higher voltage of about 3Kv to 5KV instead of 500v for my little ESL's.
Large ESL's would require a much higher current than a smaller panel or even headphones.
Therefore it would be quite dangerous to do for a large panel however it has been done.
And because of the ratio of transformer capacitance vs panel capacitance is shifted to the side of the panels, it is more feasible to use a transformer for a large ESL.
Also with the larger surface area it doesn't have to be driven as hard as a smaller one such as my desktop version to get to the same SPL level.
To compensate for this I have had to use 2X to 4X the bias voltage (10Kv) and 4X the transformation ratio (close to 1:300) than I would have to use for a larger panel that has 8X the surface area.
A good Headphone amp could run on no more than about 300v to 900v.
Just like the old tube circuits.
As for smaller drivers it would be quite feasible and A bit cheaper to do as well as having a better quality signal to drive them with..
I am glad that you are learning about transformers as it is a lot to try to soak in all at once.
I can assure you that it took me quite a while myself and I have been pounding my brain for the better part of the last three years learning about them!!! He,he,he,he
And it all started here,
Material for ESL
Material for ESL
Step-up transformer design
here are my findings in a nutshell,
My 2:nd ESL-attempt
And I am still learning !!!
Cheers!!!!
jer
Old 16th February 2013, 04:12 AM   #55
I don't remember what thread I posted the Stax's schematic in but here are some links to some drive circuits and info for a start.
Single Stator Electrostatic Headphone - issues?
Looking for HV fets for direct drive
Another direct drive thread
jer
I found the file !!!
Old 16th February 2013, 09:24 AM   #56
Banned
In my opinion there is only 1 thing very very importand for a esl transformer: IMPEDANCE
If you have controle over the impedance then the rest will follow as well.
Ohh sorry for "fase" and "phase" . I am a Dutchman....
And here some measurements from an old Sowter transformer i measured in the past.Click the image to open in full size.
Old 16th February 2013, 11:38 AM   #57
Wachara C.
Thank you Wachara, This is very much my fall back plan, and to be quiet honest without ESLtrasnformer's input I would never have considered the solution of making transformers as I know its rather involved, potentially expensive and difficult to change when you decide too.
Until I have an idea of the power and voltage I need to drive these headphones from my own measurements I wont be making any final conclusions or changes of direction. Then depending on sound I may follow a similar path if I am unsatisfied with the power transformers driving the signal. I must say the solution does sound good already, just not finished, and I suspect I have a high frequency resonance issue and need to look into damping.
I am very pleased this went well, I am a little hesitant but must admit from my web search this was one of the designs I liked. I am particularly keen on the use of high voltage NPN rather than FET as I have heard the FET's get less linear with higher voltage, and the capacitance can come to dominate their behaviour, I'm not sure how extreme this is though, as lots of stuff on the web about electronics and HiFi is just rubbish, and building high voltage FET solutions seems to have a lot more suitable devices than with bipolar NPN.
You are probably right about using a valve/tube output transformer being the best cheap option for good sound. This said I have the transformers, and depending on the tests results will decide if I buy some more transformers for the next experiment, as they will get used one day even if I go for a different solution.
This is interesting, and definitely using transistors or tubes with direct drive is a very goods option but a couple of issues worry me.
1) The power supplies will require regulated high voltages of the type that kills so more complexity at the lethal level.
2) Long term availability of high voltage transistors. I am not yet convinced that we will have many left soon, as Cathode Ray tubes, the last tubes/valves in consumer electronics are almost obsolete, meaning that high voltage transistors are hard to find today and might be impossible soon. For example I could not source KGSSHV parts from my normal suppliers.
I do tend to agree, transformers are not wonderful things but they do block DC on the stators and do isolate the inputs from the Bias on them and also as an extra benefit provide a phase split, the good sound coming from the tiny Stax transformers in the SRD-5 shows that transformers can be a good and economic solution. Depending on power results I may find inter stage transformers that some other projects have used for driving output, as a 1:6 step up ratio on 100 V amplifier might give headroom and keep the rest of the driver below lethal voltages.
I will follow the transformer drive solution further as I know in time I will use any power transformers in other projects, it is a compromise and we will see what results I get, all have been interesting so fare,
I would like to keep the final build costs for materials below 100 Euro for stereo but I will allow for higher R&D costs, especially if the components can be reused.
I would be very interested to hear other peoples measurements on current and voltage drive on Stax headphone models, and costs of building various solutions. I would also be interested to hear what problems people have with their solutions. For example the last transformer version driving the Stax Lambda Pro's I have built is a too sensitive to the position of the cable, a problem the SRD-5 and SR3 do not suffer from, I suspect this is due to the resonance damping in the SRD-5 and a series resistor might help.
Owen
Old 16th February 2013, 01:27 PM   #58
Banned
Owen
If proper designed transformer are wonderfull. You should not do trial&error to find the best normal (toridial)transformer of the shelf nor use tube output transformers unless you have no money to spend.
Ok, good transformers are difficult to find and not cheap but 200,- for a couple (=stereo) transformers is possible.
Old 16th February 2013, 01:55 PM   #59
I expect you are correct.
The first requirement for me was getting sound out at zero cost, (in the end 15 Euro) and now looking at results I got being surprisingly good considering a 1:20 step up ratio, little optimization seems worth while, and at least a step up ratio of 1:40 might resolve the issues.
The cheapest option is defiantly ebay for the original Stax driver electronics and improving them.
This said money is not a huge issue but gaining experience and measurement is the main objective in the short term.
This I can believe as I think the prices for sowter.co.uk transformers ID : 4342 or 6504 seems prohibitively high. Assuming the 200 Euro for a stereo good transformers, I can guess the performance will be excellent.
I will see very soon how the 4 transformers sound with a step up ratio of 1:40 as it costs me nothing but a little time and care, and also I have far to many audio amplifiers around the house, but some which will go to ebay one day.
regards Owen
Owen
Old 16th February 2013, 04:39 PM   #60
Thank you these links, they are interesting, and please don't think that because I continue down this path that I am dismissing direct drive.
For a direct drive system, I guess the power supply without custom/valve/tube transformers, one will need 4 normal mains transformers, one to step down for the low tension circuit, and three in series to step up for the shared high tension power supply. For duel power supplies its still going to need 8 mains transformers though the quality of these transformers should have no effect on the sound if within their specified limits.
I may look into building one or more of these circuits later and see if they improve on the basic transformer solution. At this stage I am still attaching wires to all the transformers that are now mounted and the primaries and secondaries attached to terminal blocks. Step by step, little by little this little step up system is coming together.
Thanks everyone,
Owen
Single Stator Electrostatic Headphone - issues? gentlevoice Headphone Systems 54 14th February 2013 10:14 AM
Single stator electrostatic headphone. gentlevoice Headphone Systems 16 2nd February 2010 11:33 AM
300B SE for Electrostatic Headphone Mushal Headphone Systems 5 23rd September 2005 03:29 PM
SUSY for electrostatic headphone amp Prune Headphone Systems 13 29th January 2005 01:21 PM
Copyright 1999-2017 diyAudio
