Audiostatic baffle step filter - Page 5 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 3rd May 2013, 03:46 PM   #41
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Send a message via Skype™ to Bazukaz
Originally Posted by AAaF View Post
I would have believed that a cloth would damp higher frequencies?
If so, one alternative would be to just add on backside. If it influence on higher freq, it will also influence on spread pattern, but for all we know it might improve interaction between speaker and room.
I can implement a notch filter, but in general, I believe in "making right from the start" to get the best sound quality.
Brilliant idea regarding the paper clips. We have exactly the same type at work
Really appreciate your input guys!
In general if a cloth is thin enough it will have very little effect on treble response. However the fundamental resonance is still affected by a few db.
Too thick cloth degrades sound for some reason. Even when it's placed on the back side there is a rising of treble - likely part of the sound is reflected from the back through diaphragm.
Old 3rd May 2013, 04:24 PM   #42
Banned
Look at Quad esl63 how they did it .......
Just to verify; you basicly need to add some kind of air flow resistance to dampen resonance? Sounds logical when I think of it
Old 14th May 2013, 10:22 PM   #43
AAaF is offline AAaF  Norway
The resonance peak was all sorted, thanks!
I did not get the smoothing of the other dips as bolserst though:
File Type: jpg Frekvensrespons uten filt kontra med filt unsmoothed.jpg (605.8 KB, 305 views)
Old 14th May 2013, 10:25 PM   #44
Here is the response after I increased low end gain by 3dB. Changed feedback resistor from 12k to 18k.
I'm happy for now (1/12 smoothing)
File Type: jpg Frekvensrespons etter filterjustering.jpg (584.5 KB, 290 views)
Old 16th May 2013, 08:24 PM   #45
bolserst's Avatar
Nicely done
Can you share details on the mesh you used and what mounting technique you decided on?
The smoothing of high order diaphragm modes is much easier to see when measuring near-field, with the microphone within 2cm of the diaphragm.
Mechanical Sectioning .vs. Silicon dots for resonance control
Old 23rd May 2013, 12:15 PM   #46
I used some filt. Bougt one 80% wool, 1,0 - 1,5mm thick, and one thinner 20% wool, maybe a little less than 1mm. But a quick test showed that it was actually harder to blow through the thinner filt. Thinner filt gave therefore more damping, in my case a bit too much. Though not very well tested.
I measured at a estimated 70-80cm, so I guess thats the reason why we got different results.
Old 28th May 2013, 10:42 PM   #47
Here is a comparison between nearfield(approx an inch) vs a meter, both unsmoothed. At 1m I use relatively low SPL to reduce room effect.
Its quite obvious that you need to design system for a particular distance. Is it because of the array effect that higs get more dominant when you go further away?
Old 28th May 2013, 11:31 PM   #48
bolserst's Avatar
Your unsmoothed near field measurement shows very effective damping of the diaphragm resonance. Congrats!
Yes, a line source will have a response trend that varies with listening distance unless it extends fully floor to ceiling in length. The reason for this is that for any given listening distance there is a frequency at which the sounds transitions from being highly directional in the vertical direction and starts to spread out. This may also be referred to as near/far field transition. The result is a -3dB/oct slope imparted to the response below the transition frequency. This is much more of a problem for full range ESLs than for hybrids, but even hybrids suffer from it if the panel is only 1m tall and listening distance is > 2m.
The formula for determining near/far field transition relative to a panel dimension is:
F = c * r / d^2
where:
c = speed of sound
r = listening distance
d = panel dimension
In general, for segmented ESLs you only need to be concerned with the transition frequency for the height.
But for wide unsegmented panels, you may see efffects of the width transistion frequency at closer distances.
If the ESL is extended fully floor to ceiling, the effective length of the line is theoretically infinite so the transition from near field to far field does not take place. Another way to visualize this is that the wave launched from the ESL would be contained between the floor and ceiling and have no way to expand or spread out in the vertical dimension.
More information here, including spreadsheet to plot transition points and response:
Segmented Wire Stator ESL simulator (esl_seg_ui)
Old 4th June 2013, 09:44 AM   #49
It's rather me who should send a big "thank you", for helping me resolve it.
Old 23rd January 2015, 10:29 PM   #50
Made the modification permanent and better looking, dismounted them and placed the filt below at the full length. I think the clips are looking OK. Its at the backside anyway.
@bolserst: Are you saying that there could be significant gains by extending the height of the speaker so its all the way up to the ceiling? By more or less whatever...?
baffle step compensation, zobel, notch filter dondiba Full Range 13 4th June 2012 01:10 AM
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 04:12 PM
serial filter baffle step compensation Marcelinho Multi-Way 2 17th May 2011 01:42 PM
Baffle size and shape -> baffle step saschagabor Multi-Way 1 14th December 2010 11:45 AM
baffle step in serial filter Marcelinho Multi-Way 0 30th June 2006 11:56 PM
Copyright 1999-2017 diyAudio
