| Planars & Exotics ESL's, planars, and alternative technologies |
#31 |
Ah so they used mylar, damn that stuff is thin...
#32 |
I'm getting intrested in building my own ribbons...isn't the limitation with ribbon design about the energy off the back of the ribbon? Doesn't it reflect off the magnet structures and come foward through the ribbon, causing a tiny delay related "smearing" of the original signal? And, isn't this the advantage of the heil AMT, as the energy in the back of the surface has an escape route..? The ribbon design seems easier to build, seems a doable project...
#33 |
I think you're mistaking a planar for a ribbon, if you're building a dipole ribbon the energy of the back should be equal to that of the front. I couldn't find aluminum foil that was thin enough to give me the required resistance to go completely transformer-less, I've been experimenting with making household foil thinner by using a simple baking soda solution. I've also tried electrolysis, the foil would become very thin but it would burn tiny holes in it. Anyway the foil is about the right resistance now, now I just need to find the carrier foil to prevent it from ripping apart.
#34 |
expert in tautology
For thin foil, unroll a film/foil capacitor... nicely thin stuff.
Apogee used kapton substrate, not mylar.
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
| full range + woofer OR full range + tweeter ? | Bigun | Full Range | 35 | 20th March 2013 06:47 PM |
| OGIaudio - True Ribbon - Full Range | OGIaudio | Planars & Exotics | 39 | 17th January 2013 01:34 PM |
| Korean Sonodyne S-654 Full-Range/Wide-Range Drivers | thetubeguy1954 | Full Range | 6 | 18th January 2011 10:42 PM |
| FS: Apogee Caliper Signature full-range ribbon speakers | andyjevans | Swap Meet | 1 | 22nd September 2010 11:33 AM |
