Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 7th January 2013, 07:08 AM   #1
WrineX is offline WrineX  Netherlands
Default Maybe à stupid question
Ok this Could be à dump question, does stacking 2 stators insulated from eachother give more force on THE membrane ? Like à extra winding would do on à coil ? I Could be way out here.
Old 8th January 2013, 04:27 AM   #2
No.
Raising the bias and/or signal voltage causes more force to be applied to the diaphragm.
I have measured approximately +6db of increase in sensitivity for every doubling of the bias voltage as was expected.
I have ran two panels in series before and this reduces the output as the voltage applied across each panel is now cut in half.
I didn't have a SPL meter at the time to verify the amount of drop in efficiency.
jer
Old 8th January 2013, 08:03 AM   #3
the voltage is not cut in half, maybe you dont get my question. i wondered if i put 2 front stators slapped togther with an insulating layer in between , and the same for the back. in my assumption bith stators wil act on the membrane. be it that one has a heigher DC spacing because the other stator + insulation is in the way. when you normally put panels in series that does not yield a drop either it increases output because of more mebrane. in the way i prescribe i increase stator surface while keeping the same amoutn of membrane surface. still i dont know if this would work.. maybe i might try out. but if someone had tried it or some theorie why it would not work i skip the effort of trying
Old 8th January 2013, 09:45 AM   #4
Let's start with this: Are you going to drive the extra stators with the same signal?
Old 8th January 2013, 11:16 AM   #5
oshifis is offline oshifis  Hungary
The "inner" stator will shield the "outer" stator.
Old 8th January 2013, 05:54 PM   #6
Both stators will be at the same voltage therefore there won't be any change.
In order to increase the force applied on a ESL you must raise the voltage.
Having two stators next to each other at the same voltage level results in a stator at one voltage level with no difference between them and the force stays the same.
Having two stators next to each other is not the same as having two Battery's tied in series in which would result in the doubling of the voltage.
Secondly the outer stator would have a lesser effect on the diaphragm than the first stator because it is farther away from the diaphragm.
Having the two panels in series did reduce the level for one panel and increasing the surface area may have made up the difference.
Theoretically it should.
It was about 3 years ago when I briefly tried this but I didn't have a SPL meter to verify the difference.
jer
Old 8th January 2013, 06:29 PM   #7
L
Old 8th January 2013, 06:31 PM   #8
like something to measure THE shielding is à Nice concept. So i just might try then i van only gain or it stays THE same
Old 8th January 2013, 06:35 PM   #9
It won't work.
I was going to say, if the voltage is the same then you can leave out the insulation between the stacked stators, and if you do that it's really just the same as one stator.
Old 9th January 2013, 09:52 AM   #10
Hmm Yeah . If you put it like That it kind of sound like THE title of this thread.
Ok no testing , this one can close
Okay, I have a stupid question... ptwining Multi-Way 5 9th July 2006 02:24 AM
Stupid question Leolabs Everything Else 2 8th July 2006 02:09 AM
Stupid Yes/No question Elkaid Solid State 3 4th February 2003 08:26 PM
Page generated in 0.14170 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
