a baby grand piano planar design. - Page 3 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 29th November 2012, 12:07 PM   #21
expert in tautology
bear's Avatar
Henry,
I was talking about the DIAPHRAGM.
The frames with the magnets might well bend with gravity too.
But IF you are putting these horizonatally (are you??) then the diaphragm will hang down. Dipping lowest in the center.
Ok?
What are you using for the conductive material and the substrate??
Looks like a good project so far.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 29th November 2012, 12:36 PM   #22
3 mm Aluminium tape and 12 um Mylar c. Both the small diaphragms weigh 8 grams.We will see how good it is when I play some sole piano music thro' it!?? Keep your fingers crossed.
HENRY
Old 29th November 2012, 01:09 PM   #23
tyu is offline tyu  United States
James.........thanks for ALL your Time & work on the Ribbons drivers...an posting pic...Good Job...
Old 30th November 2012, 03:29 PM   #24
Just finished wiring it up wants legs on, then got to finalize shape. Will give it a listen tomorrow, see or should I say hear what it's like. Had enough today. Some more pics to sort out.
HENRY
Old 1st December 2012, 10:34 AM   #25
Default LAST FEW PICTURES, NEARLY FINISHED!!
Here are the last few pictures, before I listen to , fingers crossed.!!Last one shows 9volt battery used for checking phase of each diaphragm.
HENRY
Old 1st December 2012, 10:49 AM   #26
Got to sort out 3 pair cables, then plug into wall sockets left of fireplace Then find a good piano CD if I can remember where I put them!? Or I may use an LP. Trouble is I moved them but where to, can hardly move with all the 24 speakers in my living room, about 20 Amps and 400 LP's + about 45 reel to reel tapes.And the 15 shelves jam packed with stuff, it'a good job I live on my own.
HENRY
Old 2nd December 2012, 09:26 AM   #27
So many settings on my Amp for this and that it is almost impossible to come to any conclusion about the sound of the mini baby grand. A press of a button on the remote changes everything, time after time. Driving me crazy.
HENRY
Old 2nd December 2012, 01:28 PM   #28
You ought to get a decent low end out of that thing !!!
What is the total surface area?
jer
Old 2nd December 2012, 03:17 PM   #29
468 sq inches the actual diaphragm area.
HENRY
Old 8th December 2012, 07:47 AM   #30
Thanks Henry !!!
The look much bigger than that !!
Here is a simulation based just upon the surface area and an Xmax of 2mm.
I just doubled the border width to the diaphragm as I don't know the exact dimensions.
I looks pretty good !!!
Cheers !!
jer
Tweaking the Sonus Faber Grand Piano Hennie Multi-Way 21 13th March 2016 09:28 AM
The ultimate Grand Piano tylersphile Planars & Exotics 37 29th November 2012 10:26 AM
Wanted Sierra/ Brooks baby grand 1" horns in walnut limono Swap Meet 10 12th August 2012 08:20 PM
X150.5 for Sonus Faber Grand Piano Home? rc5al Pass Labs 11 5th June 2008 04:15 PM
Planar design Tenson Multi-Way 6 21st January 2007 04:34 PM
Copyright 1999-2017 diyAudio
