TPL150 DIY - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 10th October 2012, 04:00 AM   #1
Lgrau is offline Lgrau  Denmark
Lgrau's Avatar
Default TPL150 DIY
I've worked a bit on a TPL-150 diaphragm in my own Magnet setup.
I wanted to avoid the iron right in front of the diaphragm, do here's the magnetsystem in FEMM:
in real life from Iron is 12mmx12mm:
Made this small enclosure for the TPL:
It measures quite good, here compared to my accuton C30:
Playing at bit more than my maximum listening level, guess around 100dB, the 3'rd harmionic is actually decreased a bit compared to the aprox 85dB measurement(note my MIC is not linear above 13KHz)
The frequency responce is very smooth and the 3'rd harmonic distortion very low.
Old 10th October 2012, 07:29 PM   #2
StigErik's Avatar
This is the first AMT I've seen without iron in front of the diaphragm! Good work! And it measures very good, looks like a lot better than the stock TPL-150.
If I understand this correctly, you have two separate magnet systems that are not interconnected in any way?
What is the sensitivity of the TPL with this magnet system?
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 10th October 2012, 08:08 PM   #3
Lgrau's Avatar
Thanks.
The magnets are not interconnected, and the sensitivity is a bit on the low side, aprox 88dB/Watt, same as my accuton C30.
Mre powerfull magnets can of coarse be used to increase the sensitivity, but around 90dB/w is fine for my setup.
There's one problem though with the TPL-150, and it's the high resonance frequency around 1800Hz.
My first AIM was to use it down to 1KHz maybe by adding a horn loading, but the low fs, is preventing a fast impulse response. I'll add some measurements, showing the problem later.
But used over 2KHz, this seems to be nearly perfect with excellent impulse response and very low distortion.
Old 11th October 2012, 06:46 AM   #4
StigErik's Avatar
88 dB should be fine for domestic hifi. The TPL diaphragm can take quite a lot of power, so thermal compression should not be an issue at all.
There is a slight resonance. I measured it to 1700 Hz on the TPL's I have had my hands on. If you want perfection, then it should be crossed over around 2 kHz I guess, making it harder to find suitable large midranges ....
Old 12th October 2012, 12:10 AM   #5
Lgrau's Avatar
Default CSD plot
Hi Here's some of the CSD plots.
As wrote earlier the resonance is clearly visible, here's plot at 1KHz and 2KHz crossover points. 2KHz looks fine and usable, 1KHz is showing quite heavy resonance.
1KHz:
used at 2KHz it's fine:
Old 12th October 2012, 12:26 AM   #6
ramallo is offline ramallo  Europe
ramallo's Avatar
Send a message via Skype™ to ramallo
1KHz:
Attachment 305933
Attachment 305934
This resonance is in dipole mode or with the TPL cabinet?
Happiness is a warm soldering iron
Old 12th October 2012, 06:41 AM   #7
StigErik's Avatar
That's a very clean CDS when you XO at 2 kHz!
If I remember correctly, that resonance is more pronounced in dipole mode without the rear chamber.
Have you tried removing the rear felt damping pad? It looks like its there on your pics.
Old 12th October 2012, 10:05 AM   #8
Lgrau's Avatar
This i measured in the enclosure which is open at the back, so this is the CSD as dipole
@Stig Yes there's a damping filt in the picture, this was not used in this measurement. When adding the filt the resonance get dampened. I'm afraid that adding a heavy damping near the back of the diaphram will also dampen the dynamic of the tweeter a bit. Did you made tests with and without the damping?
My problem in the setup is that I like to keep it 3 ways, an I was hoping that the TPL could cover down to at least 1KHz for a smooth crossover to my 6 inch skaaning bas.
(using JBL2226 15" as bas)
My system is active using Thuneau digital filter, so it's a bit expensive to upgrade to four way. :-)
But let's see when I get the skaaning up working, it might go clean above 2KHz. It's underhung, and I'm getting a new diaphragm made with foam surrounding. It's also made without spider, which I'll replace by thread spider.
Old 12th October 2012, 11:05 AM   #9
ramallo's Avatar
Without the felt damping pad, the 2 order distortion drops 20dB
Old 12th October 2012, 11:30 AM   #10
Lgrau's Avatar
Ok, then the issue is clear, no damping right behind the diaphram :-)
Beyma TPL150 vs Aurum Cantus 30130 comparison ? Paul W Planars & Exotics 4 26th April 2016 01:49 PM
Beyma TPL150 WG (H) wilbur-x Multi-Way 0 28th January 2012 01:47 PM
For Sale : Beyma TPL150 modern high efficient AMT Driver hum4god Swap Meet 1 26th March 2011 06:52 PM
Beyma TPL150 now with horn elac310 Planars & Exotics 14 9th October 2010 04:57 PM
Brand New Beyma TPL150 AMT FS thadman Swap Meet 1 22nd September 2009 09:26 AM
Copyright 1999-2017 diyAudio
