diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Planars & Exotics (http://www.diyaudio.com/forums/planars-and-exotics/)
-   -   hum in audiostatic, depends on polarity mains (http://www.diyaudio.com/forums/planars-and-exotics/220833-hum-audiostatic-depends-polarity-mains.html)
MJ Dijkstra 2nd October 2012 11:40 AM
When I connected one of my audiostatics to the mains I heard a sudden hum I never heard before. The other esl was completely silent. I turned off the amplifier but the hum continued. Obviously it had to do with the esl itself, something in the high voltage generator. I disconnected the audiostatic from the mains and the hum immediately dissapeared. Then I put the audiostatic on again with reversed polarity of the mains; the hum dissapeared. Switching again from polarity the hum returned. I connected the esl in the polarity with no hum, enjoined the music.At the end of listening I changed polarity again but then no hum.
I haven't opened it yet.
What could have caused this strange behaviour?
Ps the highvoltage section of audiostatic (old model) consist of a simple ladder circuitry. There are no transformers at the input; the 220 volt is directly fed into the ladder circuitry instead. There is a resistor between the center tap of the audiotrannies and the 'zero' of the ladder circuitry.
bolserst 2nd October 2012 01:38 PM
The symptom of hum without audio input sure sounds like the result of leakage loading down the HV supply and increasing ripple.
I know you said you turned off the amplifier, but did you leave the speaker wires connected?
If so, does your amplifier use a safety ground, such that the negative speaker wire has a low resistance path to the mains ground?
Perhaps a leakage path had developed on the PC board somewhere between the speaker input traces and the HV supply.
MJ Dijkstra 11th October 2012 07:37 AM
Hello,
With both speaker cables disconnected the problem still continues.
When time allows I will check out the HV circuitry. Maybe a diode failure?
bolserst 11th October 2012 08:20 PM
Diode or capacitor failure in the multiplier chain could certainly cause an audible hum.
But, with the speaker cables disconnected, I can't think of any failure mode that would manifest with one polarity of mains connection and not the other.
A very odd problem you have....I am interested to learn what you find when you get a chance to check out the HV supply.
Resources saved on this page: MySQL 18.75%
