Summer Project - Replication of MBL loudspeaker 101mkII - Page 3 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 21st November 2012, 11:25 PM   #21
Magnasanti's Avatar
Send a message via Skype™ to Magnasanti
Thank for the reply. I would have preferred this post to be on the other thread, but as long as its educated, and decently thought out it is OK by me. Yes that is precisely the reason I machined the metal parts first. I don't have the vacuum bagging system though I do have all the supplies. The method I will use for the oven will be to either A build a "hot-box" with temp control and various other temperature apparatus. Or B stick it in the oven following strict Post-curing procedure. This procedure changes with the type of resin used so be careful. Sounds like you have a nice assortment of tools from which to work and build with. I did scavenge the Dayton for the motor and voice-coil. Why are you in need of only the voice-coil?
Old 29th November 2012, 12:33 PM   #22
Magnasanti's Avatar
Default "Putting it all together"
The following is a picture of all the machined parts that have been assembled.
Dimensions are near exact just different perspectives.
Old 6th December 2012, 04:45 AM   #23
Magnasanti's Avatar
Default Realised working model
The following are both a picture, and a motion picture of a working mbl mid-range.
The following are the improvements that are yet to be added.
Use of wacker glue
Use of CA glue
Use of proper lamella aligning equipment
Use of "special sealing rubber"
Use of optimum resin to fiber ratio
Here is a link to the video of the working model playing. Note that all the distortion is merely from the microphone, none of it is heard in real life.
My Edited Video - YouTube
Old 13th December 2012, 03:48 PM   #24
Looking good, man. Just to clarify, the picture on the left is of your speaker, and the picture on the right is of the manufacturer's speaker, correct?
Did you end up using the samurai carbon fiber for it or what weight in oz/yd did you use? How does it sound to you?
Old 14th December 2012, 12:11 AM   #25
Magnasanti's Avatar
Yes the speaker on the left is the clone, and the picture on the right is merely for a comparison. This was a really quick and dirty version. Most of it is incorrect, it was made quick and easy just for fun while I sort out the kinks and work on the advanced version. This is why I did not post any measurements. An advanced version will be coming out next week so stay tuned. The carbon weight I am using for experimenting is 5.7 twill weave. Samurai carbon fiber and vacuum/oven curing will be on the final version which again should kick things up a notch. The actual tonality is very neutral although the highs are missing. The music floats from the very air itself even when 1/2' from the speaker it all stays in focus. I hooked up aTang Band 1337sd and the mbl, and spread them about 5 feet the sound was very good and was the most holographic sound I’ve heard. So to say the least things are looking good.
Old 14th December 2012, 12:30 AM   #26
Awesome. How many layers did you use of the 5.7 oz? The latest pic is a little blurry but I can't see any voids between the fibers. Well done. The real MBL looks like it is plain weave cut on a bias. What are you using for the surround.. Or the creased, foam-looking material between the lamellas? Also curious why you chose silicone glue over epoxy to secure the lamellas to the VC.
Keep up the good work.
Old 25th December 2012, 04:47 PM   #27
kach22i is offline kach22i  United States
kach22i's Avatar
Originally Posted by Magnasanti View Post
This project is inspired by this thread My MBL 101E replicas
I have not seen either thread before, quite ambitious of the both of you.
Good luck, after all that hard work, even the slightest disappointment can be quite the cataclysmic heartbreaking.
Tubes and Martin Logan's
Old 28th December 2012, 12:52 PM   #28
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Agree.
Congratulations on your achievements, but I think a summer vacation won't be enough, it's a *very* challenging project.
Nothing bad about that, you can always continue at a later date.
And .... good luck !!!!
Old 11th April 2013, 11:03 PM   #29
Magnasanti's Avatar
Default First official build ready
This has been a long time coming. The first official mbl clone build is ready to go, further post will show the final result and measurements. This is the set of lamellas for the first build. Test have been done to show the VF and FW contents which will be used and varied in further variations.
Old 15th April 2013, 09:59 AM   #30
Magnasanti's Avatar
This has been a long time coming. The first official mbl clone build is here, further post will show the final result and measurements. This build has all the proper materials and dimensions as the real thing. The build I feel came out very nicely. I used job specific aligning rigs and shim with which I was able to get a near perfect alignment. Ofcourse there are improvements to be made in the construction of the clone.
Summer Project - Replication of MBL loudspeaker 101mkII Magnasanti Planars & Exotics 77 21st November 2012 09:31 AM
Possible Summer Project bose301s Multi-Way 8 18th June 2009 12:25 AM
Possible Summer Project bose301s Multi-Way 8 29th May 2009 08:49 PM
Opinions on a Summer Project athos56 Multi-Way 19 13th May 2007 11:40 PM
Summer Project edjosh23 Multi-Way 19 9th June 2005 02:37 AM
Copyright 1999-2017 diyAudio
