Summer Project - Replication of MBL loudspeaker 101mkII
Casing for MT50 is finished from 3mm thick aluminium and anodized HT37 casing is still awaiting anodize.
Casing arrived... Its perfect the bolts and things fit well and complete the look while completing their function. This is for the mid-range I just need to dissemble the unit for a test fit. Completion of one mid-range is close and it will be gorgeous.
There is a different bolt that I think will look better. What are your thoughts? When complete I will show the full process of what has gone into it not a build guide just the completed parts all of them that go into one of these units.
Porgress
Here is the piece I forgot the motor cover which still needs anodizing and I started working on modeling the cabinet I was fearful I would not be able to model it as there is nearly no information anywhere but I think I have
come negligibly close. Nearly all internals have been more or less finalized. I need to purchase the Tweeter motor to dial it in and model the rest of the melon/cabinet accessories.
