Noob ESL builder looking for advice - Page 6 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 22nd September 2012, 12:45 AM   #51
Some of these as an example will get you the needed higher transformation ratio using just one core.
They may be good candidates providing their capacitance is not to high.
http://www.antekinc.com/pdf/AS-1T250.pdf
http://www.antekinc.com/pdf/AN-64115.pdf
http://www.antekinc.com/pdf/AS-1T200.pdf
http://www.antekinc.com/pdf/AN-4TK360.pdf
http://www.antekinc.com/pdf/AS-1T300.pdf
I think that they have an Isolation transformer with just 4 identical windings on it and if it is a 240v it would be great.
jer
Old 22nd September 2012, 01:01 AM   #52
I still think that would be a cheaper way to go.
And still have better performance.
But there are several good candidates from antek that might work and still have a 1:100 transformation ratio, But they are in the $40 to $80 range.
I just compiled a list 3 times and my mouse is acting up and lost it 3 times.
This one for $50 would give you 1:75 or a 1:150 ratio with the 1:75 configuration having a lower frequency capability of at least 240hz and 48v peak input for a 150watt ampilfier range and 480hz at 48v peak for the 1:150 ratio,
jer
P.S. Oh there is my list we are on a new page now !!! :/
Old 22nd September 2012, 01:10 AM   #53
I just found a thread that was performed on the Antek and another recomendation was the AN1206. I will review you just posted
Thanks,
Doc
Antek Toroidal power transformer for Step-up, Measurements (part 1/2)
Old 22nd September 2012, 01:18 AM   #54
So, with a single tranny configuration would the 6.3 v secondaries essentially be excluded?
Old 22nd September 2012, 01:22 AM   #55
Included, for the examle above.
As long as the resonate frequency of the transformer with the panel connected is above 20Khz or higher this would work good!!
jer
Old 22nd September 2012, 01:28 AM   #56
what do you think of this tranny for a single tranny application
http://www.antekinc.com/pdf/AN-1212.pdf
Old 22nd September 2012, 01:31 AM   #57
Here is another example for $50 that has an even higher ratio at 1:100 and 1:200 at the same voltages as described in post #52
http://www.antekinc.com/pdf/AN-4T550.pdf
I believe that this is something that needs to be investigated !!!
Jer
Old 22nd September 2012, 01:34 AM   #58
You would have to use twice as many to get the same transformation ratio as the 6v ones.
jer
Old 22nd September 2012, 01:49 AM   #59
Yep, I would like to explore the possibility of a custom wound torroidal which would require only needing to use one per channel. oh, and under $50.00 wouldn't be a bad price either.
Old 23rd September 2012, 02:53 AM   #60
Spent a couple hours grinding edges round on a stator. First one is slowest, hopefully.
Could save hours of trouble if the metal had a border all around. Anyone ever looked into custom fabrication?
noob question, planar speakers vs ESL on bass hello im sean Planars & Exotics 10 15th May 2012 12:23 PM
Noob needs advice jwhisl Chip Amps 3 23rd April 2012 07:47 PM
Noob looking for some advice MrBurd Tubes / Valves 13 18th June 2011 06:29 PM
Idea from ESL noob Emiel Planars & Exotics 17 27th August 2010 10:28 AM
First time builder, need advice. apetersn Tubes / Valves 26 5th July 2004 10:20 AM
Copyright 1999-2017 diyAudio
