Noob ESL builder looking for advice - Page 5 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 21st September 2012, 09:27 AM   #41
I am very glad to hear that you are making good progress !!!
Keep us posted !!!
jer
Old 21st September 2012, 10:41 PM   #42
Did some home work and made a few calls this afternoon,The Antek trannies AN0506 are out until October, the AS0506 are the 17.00 per will work.
The only difference between the 2 are, the AS0506 has a foil shield purple wire that can left un used...and the 5.00 increase....
Doc
Old 21st September 2012, 10:51 PM   #43
CharlieM's Avatar
Doc
Shaun is good to go but that's great news for anyone else needing trannies. $17 still beats any price out there and we know they sound fantastic.
Old 22nd September 2012, 12:44 AM   #44
I am not so sure about the shielded version!
The shielding may increase (maybe even double) the transformers parasitic capacitance.
This is something that needs to be tested before it is recommended as the added capacitance will lower its resonate frequency in to the audio band.
jer
Old 22nd September 2012, 01:02 AM   #45
I agree it would be best to first test, Is this foil shield present on the AN0506 just not wired?
Old 22nd September 2012, 01:07 AM   #46
I don't think it exists on the AN version.
Even if it is not connected it will still increase the surface area of the coupled capacitance just as the core itself does.
jer
Old 22nd September 2012, 01:14 AM   #47
Doy you think there could be a possible option available from Antek's catalog, short of winding a home brew?
Old 22nd September 2012, 01:18 AM   #48
Yes a higher power version such as the 100 watt transformer should work as long as the transformation ratio is the same.
jer
Old 22nd September 2012, 01:23 AM   #49
There was one that I had suggested a while back that as 4 equal voltage HV windings on it and you could add your own primary like I have down with mine.
I will find the model number for you.
jer
Old 22nd September 2012, 01:32 AM   #50
That would be great however, as we discussed I would not mind looking into having a single torroidal custom made to handle each channel. Having the capabilities of handling a 150 watts full range, and one for a hybrid build as I believe you suggested?
Doc
noob question, planar speakers vs ESL on bass hello im sean Planars & Exotics 10 15th May 2012 01:23 PM
Noob needs advice jwhisl Chip Amps 3 23rd April 2012 08:47 PM
Noob looking for some advice MrBurd Tubes / Valves 13 18th June 2011 07:29 PM
Idea from ESL noob Emiel Planars & Exotics 17 27th August 2010 11:28 AM
First time builder, need advice. apetersn Tubes / Valves 26 5th July 2004 11:20 AM
Copyright 1999-2017 diyAudio
