Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 22nd November 2012, 03:14 PM   #81
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Are you using neo or ceramic ....?
Old 22nd November 2012, 03:24 PM   #82
Paul W is offline Paul W  United States
Paul W's Avatar
Neo, N42 or N50...don't remember.
Paul
Old 22nd November 2012, 03:26 PM   #83
HellMan is offline HellMan  Finland
HellMan's Avatar
Thanx a bunch guys!!
Neos here too...
He||Man
Old 22nd November 2012, 05:16 PM   #84
dacen is offline dacen  Norway
I have used ordinary ceramic magnets for both MR/T ribbon and the bass membrane. For the MR/T I have used 20 mm X 40mm, thickness 10mm. The magnet gap is around 23mm.
I have no problem with the sensivity on this one. On the bass panel I have used 25 mm X 40 mm, thickness 10mm. On some recordings I have sometimes wanted the sensivity on the bass membrane to be a little higher, but for normal listening it is OK. Neo´s are a very good choice here. I am using separate amplification for the two.
Old 23rd November 2012, 02:08 AM   #85
DeltaStar's Avatar
Does the strength of the magnet, say N42 versus N50 make cause for more room between ribbon and magnet?
Old 23rd November 2012, 03:37 PM   #86
a.wayne's Avatar
With ceramic's difficult to get sensitivity over 80db/m/2.83v
Old 23rd November 2012, 08:51 PM   #87
Compared to the quality of sound these speakers produce the sensivity is a very minor issue. They produce an outstanding sound, so I will encourage others with DIY skills to go for it.
Old 24th November 2012, 04:14 PM   #88
a.wayne's Avatar
Neo's are way too costly unless you are building a small ribbon , so i would like to focus on improving efficiency with ceramics as best as possible , motor design etc ..
Old 26th November 2012, 12:01 AM   #89
a.wayne's Avatar
I guess no interest .....!!!!!
Old 27th November 2012, 08:43 PM   #90
hanski is offline hanski  Finland
About the magnet gluing.
My 25mm wide magnets stay well without glue. Only the two last magnets on the line repel each other so much that it causes 2mm gap.
I have also the tweeter ribbon with 10mm wide magnets. I did glue them but wouldn't do again. Gluing 400 pcs. magnets is not the most satisfying job.
help with damping resonances in aluminium? mondogenerator Multi-Way 16 30th May 2013 03:44 AM
0.6my aluminium ribbon ABJensen Planars & Exotics 103 11th April 2012 08:58 AM
Ribbon tweeter/mid suggestions craigwalsh Multi-Way 13 1st November 2008 08:36 PM
want to build a DIY ribbon, need suggestions thadman Planars & Exotics 16 10th June 2006 06:39 PM
Ribbon Tweet suggestions.... eastcoast Planars & Exotics 0 28th March 2005 07:33 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
