Diy AMT - Page 7 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 20th November 2012, 10:36 AM   #61
JohnL is offline JohnL  United States
JohnL's Avatar
Just FYI:
Air Motion headphones by Precide.
ergo eng
Old 21st November 2012, 01:52 PM   #62
Originally Posted by JohnL View Post
Just FYI:
ergo eng
Thanks for the link. I found another AMT headphone by TakeT (piezoelectric too). There's a good chance that I'll buy some Beyma diaphragms to experiment with.
Old 21st November 2012, 05:39 PM   #63
I tried to make a diaphragm with 50my mylar it didnot turn out well.
My next was with 25my sail repair mylar tape ,and her is the messurement:
[IMG]Click the image to open in full size.[/IMG]
Red is ESS, blue Diy I dont have calibrated messurements ,distortion messurements is not comparable.
It works fine from app 1500 Hz.
I have seen another alu mylar tape:http://simaintl.com/store/aluminum_mylar_PET_tape.html
I could maybe etche it like print cirkuit board.Sorry for my English.
I have made dravings in Google SketchUp:
I can print on my alu/paper.Is it possibly to print on alu mylar?
Bernt
Old 22nd November 2012, 06:51 AM   #64
That's already pretty impressive. They have the same FR anomalies - all enclosure related then? (No EQ?)
Do want to etch the circuit like this guy did for planar magnetic headphones?
My DIY Planar Magnetic Headphones and Drivers
I wonder if it is enough to physically press a regular structure like the heatsink against the foil, to mask it. Like, put the foil in a container, press mask down on it, add the liquid, remove liquid, remove the mask.
Old 22nd November 2012, 01:58 PM   #65
A couple more ideas for the mask -
The pattern is simple so a stencil should be good enough - like drawing/painting through the slits in an air grill, or using your heatsinks like a stamp.
What do you think?
Old 28th November 2012, 04:29 PM   #66
iI have found a new tape app 12my mylar and 8my adhesive:Polyester Tape : 3M UK & Ireland
It is thermosetting rubber adhesive.
At wich temperature set´s it??
Mylar is the same as polyester and PET.
Bernt.
Old 29th November 2012, 11:20 AM   #67
Check out these thermal foil heaters
http://www.omega.com/Heaters/pdf/KH-KIT.pdf
Some of these etched kapton heating elements have some pretty nice looking traces for audio use.
Old 29th November 2012, 12:15 PM   #68
Bernt,
maybe I missed this, but how do you get the electrical contact to the aluminum trace? Soldering aluminum is difficult enough, but on a mylar substrate, this would be a no-no.
Also, why are you trying to make the diaphraghm from scratch when you can buy from PE?
Old 2nd December 2012, 03:43 PM   #69
Capslock,here is a picture that shows it:
I press a copper U to make kontact.
I have tried the new tape,on 2 diaphragms,one sized as ESS and one 20% larger:
Green is the large one.
Messurements are not calibrated,distorsion cant be compared.
I have a diaphragm from PE ,its the great Heil from ESS.I would like it to play deeper.
Bernt.
Old 3rd December 2012, 08:09 AM   #70
Impressive progress. So both those FRs are home made? Are those horizontal bits of tape conductors or for rigidity?
AMT diaphragm DIY basics. graeme uk Planars & Exotics 2 9th December 2010 09:17 PM
DIY AMT: which of the three replacement diaphragms to use? capslock Planars & Exotics 3 4th July 2010 05:26 PM
big AMT Diy Charcoal Planars & Exotics 27 13th October 2008 06:41 AM
Diy Amt ? woody Planars & Exotics 0 24th September 2005 11:17 AM
Diy Amt JohnL Planars & Exotics 4 29th April 2005 03:16 PM
Copyright ©1999-2017 diyAudio
