Diy AMT - Page 22 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 13th March 2013, 09:59 AM   #211
Originally Posted by solhaga View Post
The difference between the N:s is the square root of the division if I remember it correctly.
So N52 is 1,22 times stronger than N35. But you must analyze every circuit as there can be saturation (for iron it is 2T) that minimizes the fields.
What field strength do you get with 6 mm and 10 mm iron and N52 ?
The interesting issues are:
1. How much iron are needed if N52 are used ?
2. How weak magnets can be used for a given iron to get maximum field strength ?
Old 13th March 2013, 10:08 AM   #212
solhaga is offline solhaga  Sweden
I guess you are asking me to do the analysis.
Have you tried to use FEMM yourself?
To avoid cluttering this thread, perhaps I can mail you? I´ve sent you a PM.
Also uploading pictures to the forum takes time, so a mail conversation is better.
Maybe the end result can be posted here.
Old 15th March 2013, 05:45 PM   #213
I have made a "Kithara" model:
[IMG]Click the image to open in full size.[/IMG]
I have used my 6x10x70mm neodynium magnets,and tried with a 4mm thick diaphragm.
Sensivity is much higher,but I hane not made any measurements yet.
I am waiting for my new magnets to arive.
Bernt
Old 15th March 2013, 08:59 PM   #214
Looking great!
Old 17th March 2013, 01:23 PM   #215
@båndsei: I sent you a PM.
Old 18th March 2013, 09:05 PM   #216
I got my magnets from Polen.
I have tested the new magnetsystem with the 7,5mm thick magnets and 5mm.thick diaphragm.
It does not seem to improve the performances regarding THD and FR.
I have to make more measurements to be sure.
Bernt.
Old 19th March 2013, 05:25 AM   #217
Did you get higher excursion?
Old 19th March 2013, 05:30 PM   #218
It is not posibly to see any motion of the diaphragm course of the magnetsystem.
Bernt
Old 19th March 2013, 05:59 PM   #219
Bernt
I tested a Mark & Daniel AMT with a 1.5 volt battery and I cannot see any movement even if I used a 10x magnifying lens..
The Mark & Daniel AMT have ca. 700Hz lower bandwidth and ca. 89dB sensitivity.
With my AMTs the lower (-3dB SPL) bandwidth are ca. 100Hz (due to limited diaphragm area), but are designed for DC operation...
So there I can se the movement of the diaphragm with the naked eye as 1.5 volt moves the diaphragm ca. half xmax, and as every second fold / pleat moves in opposite direction the movement are then very easy to see..
Old 20th March 2013, 07:06 AM   #220
Perhaps it is the pleat folds themselves.
If a foldering "machine" with thinner plates where used, much sharper edges would be the result.
Shouldn´t it result in better compliance and also a more V-shaped folds of the diaphragm rather than U-shaped with your current method?
And as such compressing/decompressing the air better giving a higher SPL?
AMT diaphragm DIY basics. graeme uk Planars & Exotics 2 9th December 2010 10:17 PM
DIY AMT: which of the three replacement diaphragms to use? capslock Planars & Exotics 3 4th July 2010 06:26 PM
big AMT Diy Charcoal Planars & Exotics 27 13th October 2008 07:41 AM
Diy Amt ? woody Planars & Exotics 0 24th September 2005 12:17 PM
Diy Amt JohnL Planars & Exotics 4 29th April 2005 04:16 PM
Copyright ©1999-2017 diyAudio
