| Planars & Exotics ESL's, planars, and alternative technologies |
#21 |
#22 | |
#23 |
a.wayne, just for my interest
Did you measure scintillas current and voltage under full power in 1ohm model, if yes, which values did you have and how did you measure? |
#24 |
Full power...!
No we tested at our listening avg , the scinnies was that of a friend who had custom build amplifiers , he listens loudly 90-93db avg din , his amps were rated @600 /1ohm the designer told me they would not require more Than that , the fact that he never tripped his 15 amp speaker fuses was a clue .. On my ribbons I have measured voltage at an avg din of 86db impedance 1 ohm and agree with his assessment . Even when pushed at higher levels I very rarely ever blow the 10 amp speaker fuses and when measured I was using 7V rms into the midrange ribbon (1ohm) at normal listening levels ... Of course if you want to exceed 100db consistenly then I would suggest double that ,(600) figure and those who do most times damage the bass ribbon .. Regards , Last edited by a.wayne; 26th July 2012 at 03:45 PM. |
#25 |
expert in tautology
not very experienced personally with them, but... putting a resistor in series with the bass ribbon will definitely increase the Q and decrease the DF... probably making for a warmer sounding bass?
Also, I was under the impression that amorphous cores were best at HF, and lacked inductance at LF, so were less than optimum for LF applications... _-_-bear
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#26 |
Yes bear, thats why my trafos should work only for mid and high.
No res. in series with woofer, the scintilla has a full and rich bass, some people found it to much and you need a real huge resistor. a.wayne, i had krell mda 300 driving scinnies, and twice my main fuse in the appartment rated at 50 Amperes at 230 Volt were blown when i gave full power with some mid bass impulse. BTW, the MR itself is only 0,06- 0,07 Ohms, then there are some wires, connectors and a preresistor (foil type). So if you had real 7 V on the MR, how many amperes ??? On the other hand, since i am a certified apogee woofer installer, after installation of new woofers i do some tests with amps minimum 1200 Watt into 1 ohm and its for woofer test especially. |
#27 |
Yes if you drive the Krells to full power with test signals absolutely , you will not come close to doing such when playing music ...
Regards , |
#28 | |
Actually one need a special additional device for equalization (similar like a RIAA equalization for record players), independend of the fact, whether a impedance matching transformer is in use or not. I doubt, that it is possible with passive components in front of or behind the transformer (perhaps a foil capacitor of 47mF resp. 47.000uF and a low impedance 30 mH inductor is necessary only for remove the low frequency peak by 35 Hz). Last edited by tiefbassuebertr; 26th July 2012 at 06:21 PM. |
#29 |
Add .5ohm resistors and forget about it , the amplifer will handle the load then and no transformer to cloud the sound ...
#30 |
tiefbassuebertrager
There exists no scintilla MK 4. Like i wrote before, the german thing is a clone and has nothing to do with the real apogee! Actually lawyers are involved to clean up this mess! The measurings shows a peak at apx 35 Hz, which is part of every apogee woofer, but: The real challenge with apogee is the woofer tuning, which is not done correctly with this clone, for sure! How to do it, is still our certified installer secret. This peak( if done well) should not be equalised, since this kind of woofer is a dipole, is very depending from placement( distance to rear wall) and not a box and if executed well, the apogees have a kind of bass, which we apogee fans appreciate very much. No boxy sound, but full and rich bass and dipole mid/highs.... The rest of the frequency response is not very scintilla like, since its a clone! Not a real good one IMHO. The impedance response is not visible here, but originally its demanding the most power in the transit area woofer/MR around 300 Hz and below. Adding a resistor will change the woofer sound very much due the altered Q and need a lot more amp power just to produce heat. 600 Watt Resistors are a challenge to. Some folks believe resistors do no not change the sound, other ones are convinced they do. Count me in the second ones. This impedance thing with the scintilla seems to keep all folks in red alert mode, but it is a problem since more than 25 years and it will not go away. Its stupid to make a clone with the same problems, IMHO! Thats why Apogee Acoustics in Australia comes with new models, impedance higher than 3 Ohms and efficiency apx. 95dB/ 1 W 1m. Use every amp you like, basta. |
| Apogee Scintilla amp | Thomas B | Pass Labs | 27 | 7th July 2012 04:12 PM |
| Valutronic speakers (kits) information wanted | AlejandroR | Multi-Way | 8 | 1st December 2010 07:01 PM |
| Apogee Scintilla capacitors | Dr.H | Planars & Exotics | 9 | 7th June 2009 04:35 PM |
| Wanted: USB board for Apogee mini-DAC | Puggie | Swap Meet | 0 | 3rd April 2007 10:46 AM |
