Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 17th June 2012, 09:55 PM   #11
Rullknufs's Avatar
Send a message via Skype™ to Rullknufs
I will follow this project with enthusiasm. I've heard the MBL 101 Extreme in Stockholm and it sure was a good experience
My audio and DIY blog: http://phimusic.blogspot.se/
Old 18th June 2012, 02:18 AM   #12
expert in tautology
bear's Avatar
Looks to be a straight forward magnetic circuit with a standard voice coil - looks very overhung - on the end of the "melon" petals... the VC pumps up and down and the petals move in and out in response...
otoh the VC may be pushed into the gap when the unit is assembled... gotta look closely at the pix, I haven't yet.
If you look at the Walsh (Ohm F) driver, it is really quite similar except the "cone" on the MBL is different...
The MBL is frightfully low in sensitivity, so be sure to max your magnetics and get the gap right...
I'd be concerned about the VC moving linearly in the gap, having seen how they assemble it. Very surprising to me that they seem to attach the "petals" to the VC former after the petals are connected to the opposite side. I would have expected to do it in the reverse fashion...
Also I am surprised at the damping material on the reverse side of the bass petals, and the fill inside the midrange...
seems to me that forming the petals accurately is going to be a bit of a difficult thing to do, and essential to the operation of the driver as well...
where did you find the pix of the manufacturing process?
Guess MBL is daring anyone to try it themselves!!
Please do post your progress, successful or not!!
_-_-bear
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Old 18th June 2012, 08:24 AM   #13
Send a message via Skype™ to Magnasanti
_-_-bear
The pictures of the manufacturing process were found after days searching on the web finding literally all i could.. I will surely be posting progress updates but before that i am still learning about FEMM and magnetic circuit design. Also Mbl states that the other end opposing the V-C is attached to a thrust bearing what exactly would this add?
Old 20th June 2012, 12:55 PM   #14
expert in tautology
bear's Avatar
On the bass "melon"? A thrust bearing??
Perhaps a mistranslation from the German?
I would think that over there is more or less a hinge, so that the bending motion is not impeded by stiffness. So, the hinge would need to have stiffness in the vertical direction (the way that the VC is pushing - that vector) but be able to bend outward to permit free flexing of the petals... or not. Pure conjecture.
It might be marketing hype too... the connection to the VC would likely be the *same* as the connection on the top.
educated guesses... or uneducated blabbering... either way about the same value?
_-_-bear
_-_-bear
Old 20th June 2012, 02:04 PM   #15
VALEMAO is offline VALEMAO  Italy
Me too i'am tring to replicate it...after 3 years of R&D i realized mid and tweeter.
Quite sadisfay, but an updated version is ready to be realized ..
I am involved in woofer contsruction at the moment....
and i just wonder where did you read that the aluminum lamella are made of 2 pieces glued togheter?
Thikness?
Old 20th June 2012, 07:16 PM   #16
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Wow, difficult project , getting the mechanicals right will almost be as difficult as getting them to sound right , then of course the amplification necessary to power them to reasonable levels .. May I suggest laminated foil until you get the mechanicals right , before attempting carbon diaphragms..
MBL has been at this speaker for decades , the early ones where soft and delicate sounding ,
good luck !!!
Old 21st June 2012, 06:19 AM   #17
_-_-bear
Actually the gap where the lamellas are fixed has to be large enough to permit them to vibrate. The trick is to choose the correct glue. Mbl is supposed to use a silicone rubber glue. Furthermore, is very important that does exist an axial rigid connection to the thrust bearing, otherwise it works as a low pass filter.
I touched the lamellas wilhe the loudspeaker was sounding and it doesn't have a large excursion...as expeted.
Old 23rd June 2012, 02:41 PM   #18
AVWERK is offline AVWERK  United States
That low sensitivity of these would improve if the motor was at the top pushing down rather than trying to pulse upward? Would it not?
I listened to these at our recent Newport highend show here in California and they are quite impressive.
David
Old 23rd June 2012, 03:50 PM   #19
Remlab is offline Remlab  United States
Magnasanti
Interesting photo of what looks like an MBL midbass prototype..
http://img.photobucket.com/albums/v5...r07/mbl063.jpg
By the way, could you please provide the link or links that the assembly photos came from? I tried to find them on my own, but had no success..
Seth
Old 24th June 2012, 04:57 AM   #20
Originally Posted by Remlab View Post
Magnasanti
Seth
LOTS of sites AND brochures as well from review sites they took along time to get. I could however point you in a general direction. Try searching for jurgen reis mbl (IMAGE), and a good one is mbl 101 PDF.Ill provide some links anyway it would be a pain in the **** to go find every pic again through the web so here are some links. https://www.google.com/search?q=mbl+...w=1280&bih=601
Project for next summer. Help needed. osssyvan Full Range 5 25th February 2011 09:22 PM
Possible Summer Project bose301s Multi-Way 8 17th June 2009 11:25 PM
Possible Summer Project bose301s Multi-Way 8 29th May 2009 07:49 PM
Crazy summer project ! guitvinny Everything Else 10 22nd April 2007 08:19 PM
Summer Project edjosh23 Multi-Way 19 9th June 2005 01:37 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
