ultrasound speaker ( > 20KHz) - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 14th May 2012, 04:07 PM   #1
Default ultrasound speaker ( > 20KHz)
Can anyone direct me to a speaker/tweeter/transducer that operates well in the 20KHz to 60KHz frequency bandwidth? I know this is beyond human hearing range.
I looked at some piezoelectronics but the ones I saw cut off at this bandwidth, or no frequency specs were provided.
Something capable of 120dB would be ideal.
Old 14th May 2012, 05:07 PM   #2
jan.didden's Avatar
Possibly ionovac-type drivers
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 14th May 2012, 05:51 PM   #3
tvi is offline tvi  Australia
tvi's Avatar
TECHNICS 10th800
The 10TH400s show up on ebay Germany quite often.
Pioneer TS-ST910 are available in Japan
Rgds
James
The small part of ignorance that we arrange and classify we give the name of knowledge.
Ambrose Bierce
Old 14th May 2012, 07:14 PM   #4
Delivering that frequency range at high-decibel levels is pretty demanding of the requested driver. The Aurem Cantus G1 Ribbon Tweeter has a specified bandwidth of 900Hz-40,000Hz at 102.0 dB 2.83V/1m. The tweeter is rated for 100 watts RMS/140 watts max, so you can add 20dB to the baseline sensitivity, resulting a 122dB at 1-meter with 100-watt RMS input.
Aurum Cantus G1 Ribbon Tweeter 276-420
So, with the Aurem Cantus G1 Ribbon Tweeter, you could get to 40KHz at 122db at 1-meter with 100-watts RMS input power.
Mullard EL34
Old 14th May 2012, 08:14 PM   #5
jcx is offline jcx  United States
but if you move up/down, L/R a meter? - likely >20 dB drops/roughness from beaming at those frequencies
Old 14th May 2012, 09:32 PM   #6
Esl's can get up that high !!
I used to point my little 3.25" X 9.75" panel out the window to irritate the neighbors barking dogs and they would shut up every time I turned it on.
Then they would start aimlessly looking around when a swept the frequency randomly up and down. Ahhh,ha,ha,ha,ha,ha !!!!
I don't remember how high I was able to measure it as my amplifier couldn't get much higher than about 50khz or 60khz.
I didn't have an SPL meter at the time, but I did confirm that it was working using a microphone connected to my scope.
I believe that ESL technologies are used for the military apps that are very very powerful systems.
jer
Old 14th May 2012, 10:45 PM   #7
It's certainly true that in the 20KHz-60KHz frequency range, the driver's are going to be quite directional in nature; the horizontal/vertical dispersion patterns will be very restricted. So, you'll need to aim the drivers at your target locations; otherwise, the fall-off in projected audio-frequency response will be fairly dramatic.
But, you knew that, right?
Mullard EL34
Old 15th May 2012, 01:51 AM   #8
dheming is offline dheming  United States
dheming's Avatar
This won't get you 120dB, but here's another option for wide bandwidth ultrasonic transducers: Piezo Film Transducer - PVDF Fluoropolymer - Vibra Tabs 50mV/g - Audio Sensor | eBay
50-20khz speaker kit/drives panduro Multi-Way 0 3rd December 2010 10:07 PM
phillips subwoofer > speaker wire > digital sub nervsappy Subwoofers 2 17th December 2007 12:59 PM
Best sounding aleph ?800->20khz matsj Pass Labs 5 18th July 2007 02:12 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
==&gt;&gt; Parallel 4x LM3875 for 2 ohm speaker - pls advise.. metha Chip Amps 24 18th April 2004 08:29 PM
Copyright 1999-2017 diyAudio
